 Post subject: pin out monolithic pendrive
PostPosted: December 26th, 2016, 9:57
Hi everybody how are you?
Happy holidays
i need the pin out for a monolithic pendrive, i find a very similar pin out in the aclaboratory solbase (UFD Type 30), but every time i try to read the id each crytal (the vnr reader detect 4) give me a different id, like 002fa00a.
When i was welding the pen drive to the monothic adapter, i tested each contact to see if i have a short circuit.
if some one have a similar pin out i have very grateful
my best regards and happy holidays
 Post subject: Re: pin out monolithic pendrive
PostPosted: January 13th, 2017, 9:25
We will add this one most likely in coming update.
VISUAL NAND RECONSTRUCTOR. A big revolution in chip-off data recovery
PostPosted: January 16th, 2017, 13:27
i hope the testing has not shorted anything ,Might be special multimeters that use low voltage like 0.25 volts to test can be used
PostPosted: January 19th, 2017, 14:30
Thanks Sasha, when you belive you do the release
PostPosted: October 18th, 2017, 18:36
I know it's kinda late, anyway we added this pinout to database in one of recent updates here.
Users browsing this forum: arvika and 2 guests
