 Post subject: Adding Banks
PostPosted: January 11th, 2018, 13:52
Can someone remind me the best way to add Banks into a case retrospectively, ie without losing page structure already completed.
 Post subject: Re: Adding Banks
PostPosted: January 11th, 2018, 14:14
Go back to the Root in source structure (or you can edit structure of markers table) remove Block and add Bank (divide your dump size by number of banks to get a bank size).
Then don't forget to add Block into newly created Bank structure. You won't loose page structure unless you do edit inside the page.
VISUAL NAND RECONSTRUCTOR. A big revolution in chip-off data recovery
PostPosted: January 11th, 2018, 16:21
Thanks Sasha. Banks added. Do I need to specify a Bank position under Bank structure? If so how?
PostPosted: January 11th, 2018, 16:57
Nope, no need.
Just select your Bank structure from drop down box in Markers table.
P.S. Revising now this Bank feature, will simplify it, I see it's kinda too many steps to do such a simple thing.
PostPosted: January 11th, 2018, 17:09
Thanks Sasha.
