 Post subject: Sony 64GB SD Card Pinout - HELP
PostPosted: March 21st, 2018, 5:33
I Do not Have a Working Card With This Layout ,Can Someone Help Me With The Pinouts .I Have PC 3000 Flash And Rusolut Also "But They Do Not Have Pinouts For This .I Also Cannot Find Pinouts As i Do Not Have a Working Card
 Post subject: Re: Sony 64GB SD Card Pinout - HELP
PostPosted: March 21st, 2018, 12:31
Hello!
As Sasha said on another topic, you can send us a donor device (or patient without returning back) and we can try to reverse engineer pinout.
VISUAL NAND RECONSTRUCTOR. A big revolution in chip-off data recovery
PostPosted: March 21st, 2018, 12:36
Hello!
We got similar card few mounts ago. It was 16GB Sony card but the PCB is completely different.
You can send us a donor device (or patient without returning back) and we can try to reverse engineer pinout.
PostPosted: March 22nd, 2018, 3:04
On card should write Sony code like this: SF-8UX (example). Write it code from your card.
Odzyskiwanie danych
PostPosted: March 22nd, 2018, 8:24
I Am At Home Today Not Feeling So Well ,I Have Never Experienced So Many Deaths Of NEar Dear Once As i Have Seen In This Month ,I am a Broken Man These Days .Arvika Sir i Have Got The Rusolut Tool Also Now Now i Have PC3K and VNR .From Next Month i Will Spend a Lot of Time in SElf Study
PostPosted: March 23rd, 2018, 7:34
Arvika Sir ,
The code you are asking is on the plastic body of card .I know the exact location of the same and what you are asking for .The Code Is " SF-64UF2 " .Today Again i Got a Same Pattern Card But in 32GB .This One Has a Code SF-32UX2 .This is What i Am Saying To Rusolut ,This Card Is Very Very Common In India .I have already found a working 64GB Card With Same Pattern .But i am not sure it will have same controller or NAND memory ID ,I am Planning To Send It To Poland To Sasha and Company .I wanted to ask you that does the 32GB With same pattern have same controller and memory Id ,I am Sure You Know This :D .
PS : I still need Pattern Pinouts ,I am ready with all Stuff For Starting To Reverse Engineer Pinouts And i Have Done a Few Easy Once Already With Little Assistance Here And There
