 Post subject: Toshiba THGVX1G7D2GLA08
PostPosted: December 11th, 2020, 7:28
This chip is not in my VNR database. ONFI identifies it as ID 50504E0100, and datasheet tells me it's 3.3V (Vcc / VccQ) and 16GB, but that's all.
Does anyone know the config for it?
 Post subject: Re: Toshiba THGVX1G7D2GLA08
PostPosted: December 11th, 2020, 7:51
This chip use other protocol. You can't read it on VNR. We have solution if you can outsource the case.
Odzyskiwanie danych
PostPosted: December 11th, 2020, 7:55
OK.
It's not a real case. I'm just toying around in my junkbox to practise, so I'll just scrap the chip.
PostPosted: July 21st, 2021, 17:06
Can you explain a bit which other protocol
PostPosted: July 22nd, 2021, 1:13
admittedly 2 seconds of research, so YMMV, but looks like maybe Apple PPN NAND.
solution possibly https://multi-com.eu/,details,id_pr,22037,key,nand-pro,smenu,gsm.html or https://www.aliexpress.com/item/33005771035.html
Other rabbitholes:
https://nand-pro.com/index.php/features/
https://github.com/SAD1992/iphone-dataprotection/issues/61
not sure what PPN means, maybe Presenting Problem NAND
If I wanted to find out, one way might be to grab a list of all the PPN chips here:
https://gsmserver.com/z3x-easy-jtag-plus-nand-kit/
and go through the list one by one looking for a datasheet. Then read that for more info
PostPosted: July 22nd, 2021, 2:01
Other rabbitholes:
HeeHee ,
Two Seconds on research on the links you provided and its " PPN (Perfect Page New) " :D ,Bloody Hell 32 and 64 bit chips :|
PostPosted: July 22nd, 2021, 5:06
Yeah, I was at work and didn't have time to go deep, but was curious. Thanks! I Will have to read up on it.
Wish I could afford some of those Phone kits.. they look pretty fun. Though would never get time
