Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: Introduction of MRT Data Recovery Software 20170705 Version
PostPosted: July 21st, 2017, 4:36
MRT data recovery software has been updated to a new official version on July 5th, 2017, and the new version number:2.0.5.7
The new version of the download address is: http://en.mrtlab.com/downloads
Both Ultra and Express can download from the address above.
This upgrade integrates bin resource files into dll resource, the installation package has three more modules resource dll files.
Some known issues are optimized in both Western Digital utility and database utility ,such as crashes caused by online ARCO using ID to load microcode , failure for some Seagate hard disk when backup firmware to the database ,etc. The user experience will be more smoothly in the future.
Samsung utility has fully optimized the related functions with defect list and translator. Any update of S list (including the reconstruction of the S list, A list to S list, edit the defect list to write)in the program will timely update 9D,CONGFIG and other modules, so that the added defect records can take effect when power turn off and then turn on. At the same time, the upgraded Samsung utility can docking with the LBA defect list scanned by the scanner, so you can easily use the MRT scan list table to deal with bad sectors. However, it is better to backup firmware when you edit the defect list, then you can easily restore the firmware at any time. A list clear function in this upgrade supports more new series, more hard disk startup problems caused by A list problems can be solved. In addition, read and write ROM function in this upgrade supports more families, and it is compatible with more newer hard drives and has better performance. Users should pay attention that some failure disk with slow response problem may cause ROM writing failure, users should properly extend the ATA timeout value to avoid the failure.
As for Seagate utility, adding bad sectors to G-list retains the original analytical methods, but also increase more accurate way to make G list more accurate and efficient. At the same time, the 03 module reading has been optimized, partial damage of 03 module will lead to 03 module read failure, the new 03 module read method will ignore the read error as much as possible to read 03 module, the function is in the “Tools -> track backup and restore -> service area ABA read”. We provide ABA address(including Copy0, Copy1) and sector size of common 11st and 12nd HDDs. Check “error to continue” and “try to read the physical address when ABA failure “, the integrity of data extraction can be highly improved. Other modules data extraction also support the way through check on , it should be noted that the “initial service area ABA” corresponds to “Loc” in the system file list, and “read sectors” corresponds to “Size (byte unit) in the system file list “, the byte size should be converted to the sectors numbers (sector number = byte size / 512)。This upgrade also optimized the debug function, greatly increased the practicality of this function, the new version supports editing by double-click any single adaptation parameters, improving the convenience when editing some data of certain zone in certain head. Users needn’t have to manually save it , the program supports automatic preservation. Some details has been added this time, users can configure ldr by the SGT-F3CreateLDR.ini configuration file in the installation package, the directions is in the ini file. The high baud rate settings of family 0x87,0x8C, 0x9B in BootCode mode also support in this upgrade. This upgrade supports the firmware unlock and virtual start of 94 family, PC3000 does not support the firmware unlock of this family .
MRT’s development is inseparable from your support!
Email: sales@mrtlab.com Skype:sales@mrtlab.com
MRT Express & Ultra, Professional Data Recovery Tool
Email & Skype: sales@mrtlab.com
Whatsup: +8615827155998
 Post subject: Re: Introduction of MRT Data Recovery Software 20170705 Vers
PostPosted: July 21st, 2017, 8:41
Well,
Can Someone Tell Me What Is The Family Code Of 94 Family MRT is Referring To
PostPosted: July 22nd, 2017, 17:41
Here:
PostPosted: July 23rd, 2017, 2:44
vx1 wrote:
Here:
Thanks Man ,
Can someone Tell Me what All Drive Model No's Are In This 94 Series
PostPosted: July 25th, 2017, 9:00
Samsung utility still has a lot of bugs, here i post a video as an example that doesn't work for T166 family.
Last MRT version is even worse...
http://www.mediafire.com/file/a0emr0zeh ... family.wmv
My firmware database:
https://mega.nz/folder/O01DkBRI#MxP2J6ZNqXDcrX40I8MoQQ
PostPosted: July 26th, 2017, 3:27
Banned User
Hello!! :D Guys you serious? Family name for ID 94 is Pharaoh Oasis and LuxorLite is SoC (drive hardware) of Pharaoh Oasis drive :)
I solve same issue of Pharaoh Oasis drive with PC3000 last year. If you need to unlock techno mode in such drives use "F3 Arch (Common)" Utility.
PostPosted: July 30th, 2017, 23:09
software encountered a problem related to track reading process,so the firmwares displayed in the list were fake ones, which means it is impossible to gain access to actual firmware while the act of reading tracks fails
MRT Lab - Your data recovery, our committed solution.
PostPosted: July 31st, 2017, 5:09
This is MRT bug!!!
It reads error on track 0 also on good T166 donor drives.
Sediv works very well with it, i don't have PC3000 but i'm sure that also PC3000 would work great with this drive.
PostPosted: July 31st, 2017, 8:36
MRT 2057 vs Sediv 5232 - Samsung utility works good in sediv
I made this video to demonstrate that this is a real bug, not HDD defect.
I used good donor drive.
http://www.mediafire.com/file/7k5qngr78y5c922/
PostPosted: August 4th, 2017, 23:05
Hi, sir, thanks for your questions and support.
This is caused by module list load errors in some Samsung series, now we have fixed this problem, it will be solved in next software upgrade.
Email: sales@mrtlab.com Skype: sales@mrtlab.com
PostPosted: October 16th, 2017, 0:54
Do you have any idea when MRT 2.1.1.0 English version will be released? The Chinese version is out for more than 2 weeks now but no sign of English version until now.
www.datasave.ro
PostPosted: October 17th, 2017, 22:10
Thanks for your attention, we are working on the English version, once it release, I will tell you.
Any questions, please feel free to let me know.
PostPosted: October 18th, 2017, 1:43
Ok...Do you have an estimate date?...Or a deadline to this?
www.datasave.ro
PostPosted: October 19th, 2017, 13:23
Well,
This time its a paid update for chinese users who have used mrt for more then 1 year haaa haaa
PostPosted: October 19th, 2017, 23:57
I think it will be a paid update for english users too.
www.datasave.ro
PostPosted: October 20th, 2017, 3:08
I don't mind to pay for updates, but this will create more pressure on them. They can't just have a dead forum or dead support, if the clients pay them!!
ACELab partner
PostPosted: November 4th, 2017, 3:51
They prepared the page for paid user updates in user account, so I think that the update is almost ready.
www.datasave.ro
PostPosted: November 5th, 2017, 5:42
Correct but also it would be interesting to see how much we will have to pay for one software update because the software is full of bugs as we all know. So the update will probably resolve some of them but for sure will come with other bugs as well.
www.datasave.ro
PostPosted: November 5th, 2017, 8:03
Absolutely correct. But then again, we can ask for more and better.
ACELab partner
PostPosted: November 5th, 2017, 8:16
120$ i can see when trying to update software not sure its Ready yet.
Users browsing this forum: No registered users and 55 guests
