 Post subject: ReMap or sheilding bad sector in MRT Ultra for WD hard drive
PostPosted: June 22nd, 2018, 3:39
Hi
How to ReMap or sheilding bad sectors in MRT Ultra for WD hard drives?
 Post subject: Re: ReMap or sheilding bad sector in MRT Ultra for WD hard d
PostPosted: June 22nd, 2018, 3:56
may help this pdf
Advanced-Tutorial-of-Repairing-Bad-Sectors-red-and-green-block-of-Seagate-F3-Series-HDDs-.pdf [208.75 KiB]
Downloaded 950 times
PostPosted: June 22nd, 2018, 3:59
Make sure before start 9 *All Data Will Erase *
https://www.youtube.com/watch?v=2KpAPOamgig
Watch Video for WD Drives provided By MRT
PostPosted: June 22nd, 2018, 4:22
applpp22 wrote:
may help this pdf
Thanks but I looking for WD drives, It seem this method is only for SeaGate and not works with WD drives.
PostPosted: June 22nd, 2018, 4:30
Hi, you can find the tutorials in below two links:
http://en.mrtlab.com/category/tutorial
http://us.mrtlab.com/tech/
MRT Sales consultant--Pink
Email: sales@mrtlab.com
Skype: live:sales_54921
QQ:3292109557
MRT Express & Ultra, Professional Data Recovery Tool
Email & Skype: sales@mrtlab.com
Whatsup: +8615827155998
PostPosted: June 22nd, 2018, 4:41
QQ:3292109557
Just give me the link for tutorial , not link of the mrt website! i know mrt website! Or maybe MRT Utra can NOT remap bad sector for WD devices?
PostPosted: June 22nd, 2018, 16:30
So no one has any real solution for remaping bad sector in WD drives
PostPosted: June 22nd, 2018, 17:05
Spildit wrote:
What drive model ? How many bad sectors ?
If just a few move G-List to P-List and re-format.
If you have considerable amount of bad sectors run Self-Scan.
You might need to disable heads if one surface (or more) have a huge amount of bad blocks that can't fit the P-List.
thanks for your answer
My question is for all WD Drives.
how big is P-list? and how many bad sector it can contain?
PostPosted: June 25th, 2018, 2:41
Hi, please refer to http://us.mrtlab.com/tech/wdc/198.html
MRT Sales Consultant--Pink
PostPosted: July 2nd, 2018, 4:18
Spildit wrote:
Self-Scan might be a little bit overkill ...
:roll: yeah, you have to if you want ReMap or sheilding bad sector.
The so-called "All-in-one button " is not rigorous, different HDD has different faults, different cases has different situations.
To experienced and skillful technicans, they always need to make judgement when facing different cases, no matter how powerful tools they use.
PostPosted: July 2nd, 2018, 6:41
Or you can disable entire zones if bad blocks are concentrated in a particular area, but this will reduce hdd capacity.
If you have a lot of bad blocks distributed a little bit here and a little bit there on hdd surface, then you might reallocate all those in p-list (it might be necessary to increase p-list size).
Sediv is able to increase p-list size, if is needed it's possible to increase its size by reducing user area space in passport section (example you can choose to reduce 1% of entire hdd capacity).
Waqas Ali made a video tutorial on how to do that, i followed it and worked very good.
My firmware database:
https://mega.nz/folder/O01DkBRI#MxP2J6ZNqXDcrX40I8MoQQ
Users browsing this forum: No registered users and 47 guests
