 Post subject: MRT Software Update Advance Announcement 2021.09
PostPosted: September 21st, 2021, 12:35
http://us.mrtlab.com/notice/316.html
WD
"...firmware unlocking with the locked PCB without the need of unlocked PCB"
 Post subject: Re: MRT Software Update Advance Announcement 2021.09
PostPosted: September 25th, 2021, 16:08
will be very good update if true
PostPosted: October 23rd, 2021, 9:05
Yes, it really looks like a very good update.
Let's wait for the English version.
http://info.mrtlab.com/download/
MRT data recovery software update log
October 23, 2021
MRT main program, upgrade to 2.1.7.1:
1. Add a shortcut to create a designated port
2. Optimize some underlying functions
Programmer module, upgrade to 1.0.7.1:
1. Add support for MRT programmer VER 3.0
2. Optimize the SPI read and write function to make it more stable
Western Digital module, upgrade to 2.3.7.1:
1. Added new families: Carmel(800077), VeniceR(810011), SPYG2ULT(810035)
2. Added the function of generating unlocked firmware lock ROM, currently supports mainstream hard disks such as 800065 (Chager), 800066 (Palmer), 800077 (Carmel), 810011 (VeniceR), etc., and supports reading the original ROM directly from the programmer to generate unlocked ROM, Automatic process of writing unlock ROM
3. Add T2 (190) editor (including functions such as obtaining T2, parsing T2, editing T2, etc.)
4. Add T2-based head bitmap creation function for Carmel, VeniceR, Chager and other families
5. Added the function of repairing T2 and writing T2 to the hard disk memory function, which makes the bottom layer all zero failures, read LBA automatic power-off failures, and start-up failures caused by 190 have a better solution
6. Added the firmware lock handshake function, you need to use the serial port to cooperate with the ROM that has released the firmware lock
7. Added the function of manually filling in the module ID and then reading and writing the module
8. Optimized the function of clearing the hard disk password in 127, D006
9. Optimized the ROM writing function and added support for the new hard disk large-capacity ROM chip
10. Optimized the family selection function, and added a dedicated page for the 80xx series family
11. Optimized the function of editing hard disk ID in RAM
12. Optimized the underlying database structure
13. Optimize the scanning function, increase the parameter display
14. Optimized the family recognition function, and there will be no more JET database engine errors
15. Optimized the function of batch saving module
16. The main toolbar adds a serial port connection/disconnection tool button
17. Add log/terminal switch button, serial port switch button, power off/on button on the family selection panel
18. Add full ROM read and write to the ROM list
Seagate F3 module, upgrade to 2.0.7.0:
1. Added MCMT analysis function
2. Added MCMT editing function
3. Added MCMT Extent editing function
4. Added the unlocking function of the 97 family firmware lock
5. Added 58 families plus P list, added ST3000DM001-1ER166, ST2000DM001-1ER164,
ST1000DM001-1ER162, ST500DM002-1ER14C,
ST1000DM001-1CH162, ST2000DM001-1CH164
6. Added HDD ID RAM option
7. Added virtual startup file drag and drop function
8. Added Copy0 and Copy1 options for full backup of system files
9. Added custom baud rate memory attributes (SGT-F3Default.ini)
10. Added backup system files and added a new filtering mechanism (SGT-F3SystemFile.ini)
11. Added a new system file INI file skip mechanism, with the application file skip mechanism to make the reading file system more powerful
12. Optimized the system file description display of 5400.6
13. Optimized the default check of 5400.6 resource full backup
14. Optimized the button display of the handshake mode switch on the main interface
15. Optimized the ID editing function in RAM, and added an uninitialized prompt
16. Optimized the ID editing function of some hard disk service areas to solve the problem of capacity confusion
17. Optimized the possibility of backing up volumes other than volume 0 and 3 during full backup of system files
18. Optimized the underlying database structure
19. Optimized the Glist entry opening function
20. Optimize all F3 configurations, and classify configuration files into the folder Configure
21. Optimized CAP modification capacity (greater than 2T)
DE module, upgrade to 6.0.0.4:
1. Added the following stream scan format:
Media: FLV, MP4, MP3, AVI, WAV, MKV, RM, AIFF, MIDI
Document category: PPTX, XLSX
2. Improve the speed of valid data in marked partitions
3. Optimize the underlying architecture and improve the user experience
4. Added user operation verification to reduce logic errors
5. Improve the speed of file index creation and access
6. Add internal debugging function to assist in locating problems
7. Fix the size of the saved file
Phison PS module, upgrade to 1.0.7.0:
1. Added AS2258 write LDR function
2. Added support for AS2258 virtual compiler
3. Optimized the underlying architecture of the PS module
4. Add analysis of new chip Type and other types
5. Optimized the function of reading and writing firmware
6. Optimized reading and writing CP function
