 Post subject: WD LDR need
PostPosted: December 19th, 2014, 3:20
Hi
I need LDR for this hdd.
Phoenix Computer Forensic Laboratory
http://www.databack.ir
 Post subject: Re: WD LDR need
PostPosted: December 19th, 2014, 7:48
What ROM version?
ACELab partner
PostPosted: December 19th, 2014, 10:43
pclab wrote:
What ROM version?
I don't know, this hdd detect as a model only!
No FW, No ROM version...
MRT engineer says need to load LDR
PostPosted: December 19th, 2014, 13:40
If you can read the ROM you can find the ROM version around line 0x3D750 just under the letters ROYL if you view it in Hex. It should be something like 00200049 or similar.
PostPosted: December 20th, 2014, 2:01
ROM Version: 01.32B
PostPosted: December 20th, 2014, 12:16
Post the ROM file here. It's better.
ACELab partner
PostPosted: December 21st, 2014, 3:17
ROM create with MRT
ROM_WDC WD20EZRX-00D8PB0.txt [512 KiB]
Downloaded 1030 times
PostPosted: December 21st, 2014, 8:10
upload rom.bin file after compressing it.
Data Recovery Pakistan
PostPosted: December 21st, 2014, 9:01
00010032 is the rom version you are looking for the loader.
Good Luck
Récupération de Données
PostPosted: December 21st, 2014, 9:18
Convert .txt to .bin
PostPosted: December 21st, 2014, 10:33
forget it, got the info required.
now wait if someone has this FW: 00010032
Users browsing this forum: No registered users and 17 guests
cron
