HDD GURU FORUMS http://forum.hddguru.com/ |
I need WD10EARS 00Y581 fw for MRT http://forum.hddguru.com/viewtopic.php?f=28&t=30261 |
Page 1 of 1 |
Author: | rommano [ January 4th, 2015, 15:13 ] |
Post subject: | I need WD10EARS 00Y581 fw for MRT |
Hello, everyone! I am looking for LDR for the model above for MRT card. Does anyone have it, please? For self-test, the program tells me I need module 28. But I think the loader will do…hopefully. Technology mode key : ..........................: OK RAM: Read HDD Info : ................................: OK Heads number : .................................: 4 Head map : .....................................: F SA Cyl Count : .................................: 192 Serials Mark : .................................: CE16 Control version : ..............................: 63B0 ROM: Read Rom Infos : ...............................: OK ROM Data Size : ................................: 256 Kb ROM version : ..................................: 15.3WF ROM generation : ...............................: 15.3WF Link table version : ...........................: 06.08 ROM Firmware version : .........................: 0015003W |
Author: | mrtlabinfo [ January 6th, 2015, 0:01 ] |
Post subject: | Re: I need WD10EARS 00Y581 fw for MRT |
Hi, if there are bad sectors in 28 module. Please try to enter the program with "Normal Mode" and use "SA structure test" function to test. You need to make the MRT to recognize the HDD first and then do the self-test and load LDR. |
Author: | rommano [ February 2nd, 2015, 12:53 ] |
Thank you! |
Page 1 of 1 | All times are UTC - 5 hours [ DST ] |
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group http://www.phpbb.com/ |
