 Post subject: Automatic translator repair " Seagate "
PostPosted: July 26th, 2015, 13:44
Hello!
Has someone tried this function before and worked " Automatic translator repair " with Seagate F3?
ST3500418AS
CC38
Partial sector access until ( 14000 ) sectors
 Post subject: Re: Automatic translator repair " Seagate "
PostPosted: July 29th, 2015, 10:56
The automatic translator repair for limited sector access fix, is not very good. HD Doctor of SalvationData is much better for this purpose.
However, if you know the exact LBA where begins limited access, you could do manual repair by inserting that LBA.
MRT automatic translator repair ---> not good
MRT manual translator repair ------> pretty good
PostPosted: July 29th, 2015, 11:20
Thanks a lot for reply. I will give it a try.
Thank you
PostPosted: July 29th, 2015, 11:54
You can just do it in terminal.
1. Check for NRG by entering command: T>V40
2. Clear NRG if necessary using command: T>i4,1,22
3. Maybe Clear SMART too if you want: 1>N1
4. Regenerate Translator: T>m0,2,2,,,,,22
Unless you're actually trying to regenerate a lost P-list in which case you'll need a proper tool like PC-3000.
PostPosted: July 29th, 2015, 11:58
non binding advice backup before regenerating translator
PostPosted: July 29th, 2015, 12:18
+1 Yes, this should go without saying. First thing I ever do when I plug in a drive, so I often forget to mention it.
PostPosted: December 20th, 2015, 2:27
T>i4,1,22 command does NOT clear NRG. I suggest you try it yourself and see
PostPosted: December 31st, 2015, 14:04
Hi ,
This is For Glist only
PostPosted: April 18th, 2016, 14:15
Banned User
I tried success thanks
Banned for spamming
