MRT: toshiba + DE = Garbage
http://forum.hddguru.com/viewtopic.php?f=28&t=31825
Author:  drdoc [ August 23rd, 2015, 15:12 ]
Post subject:  MRT: toshiba + DE = Garbage
Followed the instructions at
file:///C:/mrt_userdata/howtos/Recover-Data-from-G-List-Damaged-Toshiba-HDDs-with-Virtual-Translator-of-MRT.pdf
initialized toshiba
turned off techno
it will read sectors but some get errors
go to de
tell it to read from mrt0 in factory mode.
it builds virtual translator.
set read size =1
set pio mode.
I start de on master file table - sectors all green like no read errors but datais garbage - is not MFT.
I stop it.
Go to tosh util read sector 84404540 - I get MFT block as expected.
Go to de screen read same sector = garbage.
de acts like its reading successfully but its garbage.
So bottom line: DE acts like its reading good green sectors - but data is garbage...be careful.
Heres what util gets - proper mft
same sector through de = crap and no warning
Author:  Amarbir[CDR-Labs] [ December 5th, 2015, 14:26 ]
Post subject:  Re: MRT: toshiba + DE = Garbage
I Have Worked With 3 Odd Cases of Toshiba .All Worked Fine .I was Pointed To this Thread By One of Spildits Posts .I Still Have The Patients and can prove it
Author:  Spildit [ December 5th, 2015, 14:32 ]
Maybe it was because of diferent versions of MRT software / cards ?
Author:  Amarbir[CDR-Labs] [ December 5th, 2015, 15:12 ]
Spildit ,
i am using windows 7 pro 32 bit and older card with power module separately .
