 Post subject: Instruction Video of head-cutting technique for Seagate F3
PostPosted: July 15th, 2016, 22:21
Currently, there is a good demand of head-cutting technique for Seagate F3 in the field of HDD repair. However, up to the present, there is no actual effective process or technique in the market. Preciously, a method appeared that it tries to block head via putting the whole LBA of the head into non-resident G-list. Actually, this method has little effect because the blocked head hasn’t been cut and still works. Real head-cutting method for Seagate F3 should be letting servo system neglect the damaged head actually via modifying firmware. At present, in order to block the head, several simple methods are invented,such as adding to the D-list or adjusting RAP which all have big drawbacks and little effect with blocked head still working. Thus, it is hard for you to effectively repair the HDD.
We have done deep research in Seagate firmware and servo system, finally finding a real head-cutting technique for Seagate F3. The technique makes it possible to cut random head, cut zero head and redefine main head. Head can be cut whether the HDD is ready or not (such as caused by its damaged zero head), after which we define head one as main head. There is no need to adjust the adaptive parameter after the head being cut. So it is easy to operate.
We have made an instruction video to demonstrate the operation step by step. In this video, you will know the features of Seagate HDD, the head-cutting principle and technique and operation steps that is easy to follow. Just click the link attached to download this video. This is probably the most effective head-cutting method for Seagate HD. We hope it can help others.
Seagate head-cutting instruction video.rar [15.07 MiB]
Downloaded 1216 times
 Post subject: Re: Instruction Video of head-cutting technique for Seagate
PostPosted: July 17th, 2016, 22:22
Banned User
wow, seems like a very powerful tools to refurbish F3 ST disk, will go to your website for more detailed information about your products, thanks! :lol:
PostPosted: July 19th, 2016, 5:44
Nice :D
PostPosted: July 21st, 2016, 15:44
In my opinion MRT staff should focus more on data recovery utility instead of head cut or similar stuff that is needed only for hdd refurbishing.
Example of what we really need is support for SED drives!!
At the moment we can't work on new Seagate SED drives as Megaladon and Lombard families, because is not possible to access into SA, also WD SED are not supported yet (example some Hubble LT families).
When MRT will support this drives for data recovery?
Please, study a solution for SED drives, thanks.
P.S.
On this forum very few people are interested on hdd refurbishing. most of us are in DR field.
There is a new competitor (EDR) of you that now supports SED drives, it's located in my country (Italy), this means that now PC3000 is not the only that supports SED.
http://www.edrtools.eu/index.php/seagat ... or-seagate
PostPosted: July 21st, 2016, 22:09
We are also constantly researching and developing new data recovery functions.
At present, WD SED related function is being developed. And it will be launched in our next software upgrade.
MRT Data Recovery Tools, which can bear comparison with PC3000 Tools
MRT can support Seagate F3 Head/Zone shielding
http://en.mrtlab.com/contact-us
PostPosted: July 25th, 2016, 22:11
Yes. MRTLab is considering doing better.
PostPosted: July 25th, 2016, 22:23
mrtlab123 and greenhand are the same person = both banned for shilling
Dmitry
PostPosted: July 25th, 2016, 22:50
I had suspicion based on similar posts on other forums with a different user ID.
RAID Data Recovery
