 Post subject: Toshiba Hard Disk not Detecting
PostPosted: January 22nd, 2018, 3:04
I Have Toshiba Hard Disk not Detecting in DE Accessed One Partition instead 3 . i backup Data from That Partition with help of MRT DE , is it possible to repair the hdd for Re use ?? i don't want data
Here Is SA Track Reading Results
Reading track, please wait...
Track:0 head:0 backup is successful, errors:1993
Track:1 head:0 backup is successful, errors:45
Track:2 head:0 backup is successful, errors:1993
Track:3 head:0 backup is successful, errors:1993
Track:4 head:0 backup is successful, errors:1993
Track:5 head:0 backup is successful, errors:1993
Track:6 head:0 backup is successful, errors:1993
Track:7 head:0 backup is successful, errors:1993
Track:8 head:0 backup is successful, errors:81
 Post subject: Re: Toshiba Hard Disk not Detecting
PostPosted: January 22nd, 2018, 7:43
You can try to use the kill head function in Toshiba utility.
http://us.mrtlab.com/tech/toshiba/116.html
or shielding bad tracks:
http://us.mrtlab.com/tech/toshiba/77.html
PostPosted: January 22nd, 2018, 15:05
Build head map and figure out if one or more heads are damaged. If so disable that head (prevent it's use) by placing on the P-List all of the space that belongs to that head.
If MRT does allow to scan by head it's even easier. Just try to figure out if one head is not reading first.
If all heads are reading then you might need to disable zones instead.
In both cases you need to correct capacity as well.
