HDD GURU FORUMS
http://forum.hddguru.com/
Seagate Showing 3.86Gb instead 2TB
http://forum.hddguru.com/viewtopic.php?f=28&t=36383
Page 1 of 1
Author:  applpp22 [ February 3rd, 2018, 4:54 ]
Post subject:  Seagate Showing 3.86Gb instead 2TB
ST2000DM001
CC24
Problem : Showing 3.86Gb instead 2TB
Spin up Normally and Getting 2 Beep Sounds and spin Down
Not Hearing like head Stuck ,
When I am trying To Virtual Start
Original Rom Reading Failed
Can You Suggest Solution Please
Author:  melvin [ February 3rd, 2018, 4:56 ]
Post subject:  Re: Seagate Showing 3.86Gb instead 2TB
Check heads. 3.86GB is PCB.
Author:  ccc [ February 3rd, 2018, 6:43 ]
Try to disable heads in ROM one by one.
Author:  Spildit [ February 3rd, 2018, 16:27 ]
If it spins down and makes strange sounds most likely heads are gone. What do you get from the terminal ?
http://www.phpbb.com/
