 Post subject: Solving Translation Error
PostPosted: July 15th, 2018, 19:33
Hi
i had bad sector on my hdd ( model:ST31000340NS firmware version:SN06 serial number:9QJ7GJWC )
so i used this method ( http://us.mrtlab.com/tech/seagate/207.html , How to Shield Bad Blocks with P-list ) but after that, all of my translator are have problem, I used Translator Regeneration , Translator recovery , automatic Translator recovery and used m0,6,2,,,,,22 with getting this error
DiagError 0000500E Process Defect List Error
R/W Sense 00000002, R/W Error 841C0083, List Offset 00000000, File Error 00000001
but nothing works so far, what to do to repair translators?
 Post subject: Re: Solving Translation Error
PostPosted: July 17th, 2018, 16:44
So no one had my error in past? what sould I do ?
A Beginner in Data Recovery with MRT Ultra
PostPosted: July 17th, 2018, 16:45
Try to contact MRT tech support ?
PostPosted: July 17th, 2018, 19:15
not yet.
PostPosted: July 18th, 2018, 21:56
this model is not supported to shield bad tracks via P-list, I tried before
PostPosted: July 29th, 2018, 16:42
so, what can I do for sheilding bad sector?
PostPosted: July 29th, 2018, 17:01
Replace the damaged drive with one HGST drive ?
PostPosted: July 31st, 2018, 4:18
Are you kidding me? Im here to learn something to repair hard drives, not to replace just like normal user.
PostPosted: July 31st, 2018, 15:32
Those F3 ARCH Seagate drives are junk ! Why do you think that you can reepair those for re-use ? You can't.
You can "patch" them for data recovery but as soon as you do get the data extracted you should replace the drive.
You shouldn't be using ANY newer seagate F3 arch drive for important data storage even less if that drive did already failed once.
