HGST problem
http://forum.hddguru.com/viewtopic.php?f=28&t=37187
Page 2 of 2
Author:  rogfanther [ August 2nd, 2018, 17:44 ]
Post subject:  Re: HGST problem
jonbang wrote:
data-medics wrote:
It looks to me that some clueless person tried moving all sorts of chips from one PCB to the other including things like the RAM and main IC.
This is hopeless. Go to a professional jonbang, you're just making this more and more complicated and running up the final cost you'll end up paying.
Nobody has tried to move any chips. What you see is the foam between the pcb and the casing that has fastened to the pcb....:-)
Then please, clean the board and post pictures of the entire board, both sides.
Author:  fzabkar [ August 2nd, 2018, 17:50 ]
+5
Page 2 of 2 All times are UTC - 5 hours [ DST ]
