HDD GURU FORUMS
http://forum.hddguru.com/
WD5000LPVT-22G33T0 LDR file needed
http://forum.hddguru.com/viewtopic.php?f=28&t=37432
Page 1 of 1
Author:  shubhsinghal [ September 25th, 2018, 4:47 ]
Post subject:  WD5000LPVT-22G33T0 LDR file needed
need ldr for the same, anyone can help?
Author:  jermy [ September 25th, 2018, 20:00 ]
Post subject:  Re: WD5000LPVT-22G33T0 LDR file needed
over 2.5 years in the file section
http://files.hddguru.com/index.php?acti ... ty/Hubble&
Author:  shubhsinghal [ September 26th, 2018, 1:46 ]
ldr is not there
Author:  fzabkar [ September 26th, 2018, 3:16 ]
shubhsinghal wrote:
ldr is not there
11.rpm
Author:  jermy [ September 26th, 2018, 8:48 ]
with all due respect
outsource it to someone who knows what he is doing
Author:  Jirbun [ September 26th, 2018, 10:53 ]
Did you got all data recovery knowledge in one day ?
Author:  mhp666 [ September 26th, 2018, 19:03 ]
The link firmware version I think is 00002004Q.
Although I think it's fine, for the album you're looking for.
Someone with more experience than I could corroborate you.
In the most modern discs apart from the 0x11 module it is important to load the 0x411, if I am not mistaken.
Greetings.
Author:  shubhsinghal [ September 27th, 2018, 1:31 ]
Thanks, done with it.
support is always required.
Author:  sin [ September 27th, 2018, 18:40 ]
No problem, there is always a learning curve. Best Wishes from Mumbai
http://www.phpbb.com/
