 Post subject: LuxorLite-94 ST1000DM003-1SB102-Z9A5KRPD
PostPosted: September 27th, 2018, 1:40
Drive spins up in starting and spins down as terminal message appears.
i think virtual loader might help.
i am looking for the loader file please help and support with suggestions.
 Post subject: Re: LuxorLite-94 ST1000DM003-1SB102-Z9A5KRPD
PostPosted: September 27th, 2018, 2:26
The first thing you have to do is unlock the firmware.
With this you will have access to read the SA.
Once you have access to the SA, make a complete copy of all the resources of the SA, if it leaves you and then you will know that it is not a problem of heads.
I think that disk can be easy to solve, but do not rush.
PostPosted: September 27th, 2018, 6:06
i need 3D to test it virtually.
if anyone can help with that?
PostPosted: September 30th, 2018, 16:45
Most likely head(s)/pre-amp are gone ....
Fail Servo OP message in terminal + drive spin up and down to me it's 95% of times head(s)/pre-amp problem ....
You will not be able to read SA (on platters) if head(s) and/or pre-amp are gone ...
Clean room work is needed and do not open the drive in open air ...
PostPosted: October 4th, 2018, 4:04
Sure,
Thanks you so much for your guidance.
i will try to swap head and check it again.
Thanks again
PostPosted: October 4th, 2018, 12:12
I do not understand a thing of this case.
If the heads are wrong, how can the model and capacity detect without problems?
PostPosted: October 5th, 2018, 8:15
Tried Virtual Boot, Error in exchange commands.
Not Successful.
Head Swap Done, Same result.
Any more solution?
PostPosted: October 5th, 2018, 10:28
I would do the following:
First unlock the firmware to access the SA.
Then repair mcmt problem.
And I hope you have access to the data.
I hope they have not damaged their heads.
PostPosted: October 10th, 2018, 6:59
Failed to Unlock ROM.
