 Post subject: ST2000DL003 2TB Busy, No Spin, No Terminal
PostPosted: October 6th, 2018, 8:28
PCB without HDA gives ready state. (Tried with Donor PCB + Patient ROM)
PCB with HDA gives busy mode.
By entering Bootcode mode, Model & Serial Visible with 0.00 GB and no terminal access.
Any suggestions?
 Post subject: Re: ST2000DL003 2TB Busy, No Spin, No Terminal
PostPosted: October 6th, 2018, 9:01
You can start by posting the terminal output you're getting when the drive starts up.
PostPosted: October 8th, 2018, 3:05
Terminal is total blank. No single output
PostPosted: October 8th, 2018, 4:13
No Spin, No Terminal, Busy Status.
Not able to read system Files as well.
PostPosted: October 8th, 2018, 9:03
It enters directly into BootCode mode??
Is the ROM original?
ACELab partner
PostPosted: October 8th, 2018, 9:31
Yes ROM is original, Busy State so, only can enter bootcode mode.
Still Pending!!!
