ST2000DL003 2TB Busy, No Spin, No Terminal
http://forum.hddguru.com/viewtopic.php?f=28&t=37496
Author:  shubhsinghal [ October 6th, 2018, 8:28 ]
Post subject:  ST2000DL003 2TB Busy, No Spin, No Terminal
PCB without HDA gives ready state. (Tried with Donor PCB + Patient ROM)
PCB with HDA gives busy mode.
By entering Bootcode mode, Model & Serial Visible with 0.00 GB and no terminal access.
Any suggestions?
Author:  data-medics [ October 6th, 2018, 9:01 ]
Post subject:  Re: ST2000DL003 2TB Busy, No Spin, No Terminal
You can start by posting the terminal output you're getting when the drive starts up.
Author:  shubhsinghal [ October 8th, 2018, 3:05 ]
Terminal is total blank. No single output
Author:  shubhsinghal [ October 8th, 2018, 4:13 ]
No Spin, No Terminal, Busy Status.
Not able to read system Files as well.
Author:  pclab [ October 8th, 2018, 9:03 ]
It enters directly into BootCode mode??
Is the ROM original?
Author:  shubhsinghal [ October 8th, 2018, 9:31 ]
Yes ROM is original, Busy State so, only can enter bootcode mode.
Still Pending!!!
