WD5000AZLX-00K4KA0 LDR FILE REQUERED
http://forum.hddguru.com/viewtopic.php?f=28&t=37896
Author:  rajeshvns [ January 4th, 2019, 11:22 ]
Post subject:  WD5000AZLX-00K4KA0 LDR FILE REQUERED
Technology mode key : ..........................: OK
RAM:
Read HDD Info : ................................: OK
Heads number : .................................: 1
Head map : .....................................: 0
SA Cyl Count : .................................: 256
Serials Mark : .................................: 0xFE16
Control version : ..............................: 95B0
Zone allocation table : ........................: Err
ROM:
Read Rom Infos : ...............................: OK
ROM Data Size : ................................: 256 Kb
ROM version : ..................................: 45.BUF
ROM generation : ...............................: 45.BUF
Link table version : ...........................: K8.02
ROM Firmware version : .........................: 004500BU
ROM Modules:
Flash ROM dir reading : ........................: OK
Switched off heads : ...........................: Yes
Heads number : .................................: 0x2
Heads number in use : ..........................: 0x1
heads map : ....................................: 1
SA Module Dir Loading...
Load SA Module dir : ...........................: Error, suggest to load from the file
Configuration reading : ........................: Err
Author:  pcimage [ January 6th, 2019, 15:27 ]
Post subject:  Re: WD5000AZLX-00K4KA0 LDR FILE REQUERED
Is the drive clicking and/or spinning down?
Author:  rajeshvns [ January 9th, 2019, 11:49 ]
Sping and No Clinking Sound
Author:  siamak5561 [ January 12th, 2019, 3:14 ]
I suggest you to work with ram operation, load module list from hard drive and use second, most of the time works for me.
Author:  rajeshvns [ January 13th, 2019, 21:53 ]
Get ROM Data : .................................: OK
Read Ram Data : ................................: Err
Can't make head test!
load 01...
Get 01 module from HDD : .......................: failed
Get module list from HDD : .....................: failed
Solve slow in RAM...
Get 02 module from RAM : .......................: failed
Author:  siamak5561 [ January 14th, 2019, 11:23 ]
first close systme area in rom
power off , on
open system area in RAM
open system area in Rom
power off , on
with this method I solve 90% of loader problem.
Author:  Abdul Rauf [ February 1st, 2019, 10:10 ]
power off , on
power off , on
