HDD GURU FORUMS http://forum.hddguru.com/ |
Toshiba ROM write for pcb swap ?? http://forum.hddguru.com/viewtopic.php?f=28&t=38072 |
Page 1 of 1 |
Author: | HddDonorMarket [ February 15th, 2019, 12:33 ] |
Post subject: | Toshiba ROM write for pcb swap ?? |
I am still discovering DR job and MRT Ultra. I couldn't find to ROM transfer method . MRT only reading ROM. I can do hot swap transfer. But I am trying to find a method to ROM transfer unless hot swap . Any advice? |
Author: | pclab [ February 15th, 2019, 14:39 ] |
Post subject: | Re: Toshiba ROM write for pcb swap ?? |
Yeah, only by swapping the ROM physically. |
Author: | HddDonorMarket [ February 15th, 2019, 15:02 ] |
Then what for reading ROM. If only one way hot swap. Not need to read ROM . Lol ))) |
Author: | HddDonorMarket [ February 19th, 2019, 13:10 ] |
My English poor. I miss something that you post. So , is that Read CP files from patient And write to new pcb. Is that mean rom transfer? |
Author: | data-medics [ February 19th, 2019, 14:52 ] |
HddDonorMarket wrote: Then what for reading ROM. If only one way hot swap. Not need to read ROM . Lol ))) Some of us like to make a backup of the ROM in case it gets cooked during the physical transplant. At least you can still write it back using an external programmer if something goes wrong. It's a best practice thing. |
Author: | HddDonorMarket [ February 19th, 2019, 18:08 ] |
Spildit wrote: HddDonorMarket wrote: My English poor. I miss something that you post. So , is that Read CP files from patient And write to new pcb. Is that mean rom transfer? If you have 2 PCBs with SAME ROM MAIN CODE and of course diferent adaptives and unique CPs (ROM MODULES) You can : 1 - READ CPs on Drive A. 2 - On Drive B (donor) WRITE CPs from drive A (you should not write platter CPs like DD - P-List). 3 - Move PCB from drive B to drive A. If MAIN ROM code is the same PCB should work on drive A now. Thanks for info. I will make practise about that point. If I remove pcb before get CP files so that files from ROM chip. ..And I would write them to donor. Meaning that files not from platter. Right? |
Author: | HddDonorMarket [ February 24th, 2019, 8:52 ] |
I can read 65gsx CP files with lost rom chip Hdd. Only DD cannot read. And zone table data wrong. Which CP file include zone information? Any suggestion? |
Author: | pepe [ March 7th, 2019, 20:59 ] |
it is possible to write rom using hyperterminal. or write CPs but that won't transfer the code... you can read CPs from your donor pcb any time but DD is on platters, for which you would need native adaptives from native rom which you don't have as far as i understood... I am pretty sure sa access can be restored relatively easily but where do we go from there? pepe |
Author: | HddDonorMarket [ March 16th, 2019, 9:39 ] |
Spildit wrote: I think that you are confusing that HOT swap thing with swaping ROM chip. HOT SWAP is when you swap the PCB from one drive to the other without removing power. Swaping chips doesn't have anything to do with HOT SWAP apart from the HOT soldering station. Yes . I learned hot swap means now. Thanks |
Page 1 of 1 | All times are UTC - 5 hours [ DST ] |
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group http://www.phpbb.com/ |
