ST3000DM001
http://forum.hddguru.com/viewtopic.php?f=28&t=38768
Author:  jonbang [ August 17th, 2019, 17:35 ]
Post subject:  ST3000DM001
Anything to do here? It spins up, click twice and spins down It gets ID, firmware etc, but says the size is 3,86gb. Is this dead or is there something i can do?
Author:  mhp666 [ August 17th, 2019, 18:06 ]
Post subject:  Re: ST3000DM001
Hi.
I think it is a lost case.
Every time the needles pass through that area I think they will break.
Also if I'm not mistaken, the other surfaces of the HDD have the same scratch.
A greeting.
Author:  MindMergepk [ August 18th, 2019, 5:29 ]
most likely gone, if customer is willing, partial recovery can be attempted...
Author:  pcimage [ August 18th, 2019, 8:00 ]
Yes, maybe possible for partial but requires thorough investigation...
Not cheap :-(
Author:  jonbang [ August 18th, 2019, 12:54 ]
Ok, do you know how to partially recover? I have both mrt and pc3k available.
Author:  digisupport [ August 18th, 2019, 12:59 ]
In your case I would remove top head, do the necessary ROM modifications to get the drive to start without h5
Author:  pcimage [ August 18th, 2019, 13:01 ]
After checking all heads for debris under the microscope of course! :-)
But in any case, it’s a cleanroom job.
Author:  digisupport [ August 19th, 2019, 0:01 ]
I take so many things for granted, thank you for completing my answer pcimage :)
