HDD GURU FORUMS
http://forum.hddguru.com/
WDC WD10JPVT-60A1YT0 - Western Digital 1 TB
http://forum.hddguru.com/viewtopic.php?f=28&t=40558
Page 1 of 1
Author:  reliableservice [ October 31st, 2020, 9:32 ]
Post subject:  WDC WD10JPVT-60A1YT0 - Western Digital 1 TB
Log :
Technology mode key : ..........................: OK
RAM:
Read HDD Info : ................................: OK
Heads number : .................................: 4
Head map : .....................................: F
SA Cyl Count : .................................: 256
Serials Mark : .................................: 0xE816
Control version : ..............................: 95B0
Zone allocation table : ........................: OK
SA SPT : .......................................: 1420
ROM:
Read Rom Infos : ...............................: OK
ROM Data Size : ................................: 256 Kb
ROM version : ..................................: 03.3VB
ROM generation : ...............................: 03.3WB
Link table version : ...........................: TP.44
ROM Firmware version : .........................: 0003003V
ROM Modules:
Flash ROM dir reading : ........................: OK
Switched off heads : ...........................: Yes
Heads number : .................................: 0x4
Heads number in use : ..........................: 0x4
heads map : ....................................: 0,1,2,3
Load SA translator : ...........................: OK
SA Module Dir Loading...
Load SA Module dir : ...........................: OK
Configuration reading : ........................: OK
Master Password : ..............................: has not been set
User Password : ................................: has not been set
Head Test...
Head: 0 Write data : ..........................: OK
Head: 0 Read data : ...........................: OK
Head: 1 Write data : ..........................: OK
Head: 1 Read data : ...........................: OK
Head: 2 Write data : ..........................: OK
Head: 2 Read data : ...........................: OK
Head: 3 Write data : ..........................: OK
Head: 3 Read data : ...........................: OK
Executing SA structure test
Read type : ....................................: By Track
ID : Copy : Importance : ABA : Size : Read : Hdr : CS Value calc/read : Version : Desription
0001 : Copy0 : B : 00034701 : 20 : Ok : Ok : 886816F7/886816F7 : 00020000 : Modules directory
0002 : Copy0 : B : 00034721 : 5 : Ok : Ok : A47098C9/A47098C9 : 00080000 : Configuration (HDD ID)
0003 : Copy0 : As : 00001BB1 : 5E : Ok : Ok : 25BBCD00/25BBCD00 : 00020000 : Format Select Data Module
000C : Copy0 : B : 0000117E : B : Ok : Ok : 35562912/35562912 : 00010100 : Models table
0011 : Copy0 : B : 00034A0E : 480 : Ok : Ok : 49843584/49843584 : 0003003W : microprogram code
0012 : Copy0 : B : 00034EAE : 31 : Ok : Ok : 467872F9/467872F9 : 0003003W : microprogram code
0031 : Copy0 : Ad : 00000BD9 : 5A5 : Ok : Ok : A15EB63F/A15EB63F : 00400000 : Translator
0032 : Copy0 : Ad : 000011B9 : 3C : Ok : Ok : 0713A8DC/0713A8DC : 00170000 : Relo Bad Block Module
0033 : Copy0 : Dd : 0000027D : 95C : Ok : Ok : 6E077D64/6E077D64 : 00150000 : P-List (Primary defect list)
0035 : Copy0 : Dd : 00000020 : A : Ok : Ok : 4BFD1E15/4BFD1E15 : 1025-J12 : SA Defects
0036 : Copy0 : Ad : 000011F5 : C : Ok : Ok : 4EB0B3EA/4EB0B3EA : 00010000 : T-List Module
0040 : Copy0 : As : 0000120B : 172 : Ok : Ok : 4B46F9EC/4B46F9EC : 00010000 : Adaptive data
0049 : Copy0 : As : 00001B95 : E : Ok : Ok : FDD1A280/FDD1A280 : 00010000 : Adaptive data
SA structure test is completed!
See the Attach Image -
While Making IMAGE or DE it gives errors?
what is Best way to get data ?
Author:  unknown [ November 1st, 2020, 14:16 ]
Post subject:  Re: WDC WD10JPVT-60A1YT0 - Western Digital 1 TB
Further diagnosis required.
Did you try to read random sectors ?
Author:  reliableservice [ November 2nd, 2020, 2:56 ]
Yes few sectors read and few not read.
even try disabling head 0,1,2,3 - after few sector read it gives error on all head.
it seems user access area has problem?
Author:  unknown [ November 2nd, 2020, 8:52 ]
Head/s problem and/or media degradation.
Did you try to read with every single head separately?
Author:  reliableservice [ November 5th, 2020, 13:36 ]
sorry customer call back hdd.
case closed :!:
http://www.phpbb.com/
