WD family Pinclite WD320AAJS ROM copy failed
http://forum.hddguru.com/viewtopic.php?f=28&t=42890
Author:  KangKung [ November 26th, 2022, 4:21 ]
Post subject:  WD family Pinclite WD320AAJS ROM copy failed
I am having problem to copy ROM from old WD family Pinclite 320Gb WD320AAJS using MRT, it is always failed. Other model WD 80Gb WD800AAJST, also have same problem . There is no 8pin IC for copy using external programmer as my option, anybody know how to copy ROM from those WD hard drive?
Thank you.
Author:  Disk Solution [ November 26th, 2022, 5:08 ]
Post subject:  Re: WD family Pinclite WD320AAJS ROM copy failed
You need to rebuild ROM with new PCB.
Author:  einstein9 [ November 26th, 2022, 7:09 ]
use compatible ROM (something close by SN) should work if drive is healthy
or hotswap
Author:  KangKung [ November 26th, 2022, 8:36 ]
Hi einstein9,
Thanks for advise, I will try to get same hdd.
