HDD GURU FORUMS http://forum.hddguru.com/ |
WD 10SPZX super slow http://forum.hddguru.com/viewtopic.php?f=28&t=43333 |
Page 1 of 1 |
Author: | Adam112255 [ May 11th, 2023, 6:28 ] |
Post subject: | WD 10SPZX super slow |
WD 10SPZX responds very slow, it spins no clicking sound and connect to MRT shows HDD information also can open file explorer in MRT and see all the files and view them but when we try to clone it to another hard drive it copies super slow. already unlocked the ROM and MRT support had a look said head 1 is weak but I tried to test the heads in MRT and both passed with OK. any help would be appreciated Technology mode key : ..........................: OK RAM: Read HDD Info : ................................: OK Heads number : .................................: 2 Head map : .....................................: 0 SA Cyl Count : .................................: 512 Serials Mark : .................................: 0xFE16 Control version : ..............................: 5460 Zone allocation table : ........................: OK SA SPT : .......................................: 1944 ROM: Read Rom Infos : ...............................: OK ROM Data Size : ................................: 1024 Kb ROM version : ..................................: 02.1AP ROM generation : ...............................: 02.0HP Link table version : ...........................: 01.3C ROM Firmware version : .........................: 0002000P ROM Modules: Flash ROM dir reading : ........................: OK Switched off heads : ...........................: Yes Heads number : .................................: 0x2 Heads number in use : ..........................: 0x2 heads map : ....................................: 0,1 Load SA translator : ...........................: OK Number of reserved tracks in SA : ..............: 0x9 SA Module Dir Loading... Load SA Module dir : ...........................: OK Configuration reading : ........................: OK Master Password : ..............................: has not been set User Password : ................................: has not been set Head Test... Head: 0 Write data : ..........................: OK Head: 0 Read data : ...........................: OK Head: 1 Write data : ..........................: OK Head: 1 Read data : ...........................: OK Start Solve... Cheack Head Data And CheckSum : ................: OK Write Data : ...................................: OK Start Solve... Cheack Head Data And CheckSum : ................: OK Write Data : ...................................: OK |
Author: | michael chiklis [ May 11th, 2023, 11:35 ] |
Post subject: | Re: WD 10SPZX super slow |
MRT head test when is ok just means that heads are still alive. So it doesn't mean head 1 is in good condition, that head can be weak as MRT support tech told you. Weak heads do read slowly or read badly in many zones. |
Page 1 of 1 | All times are UTC - 5 hours [ DST ] |
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group http://www.phpbb.com/ |
