 Post subject: Stuck with a certain flashes
PostPosted: February 28th, 2020, 7:18
So I have been flashing SAS HDD's using sq_untils I have had a lot of success when the firmware is already available to flash in a .LOD file however I am having an issue with a couple of different drives.
I find I have to flash HDD's after formatting to 512 block size when they have come out of Hitachi servers, so they have the Hitachi firmware on them such as 7FA6 on a ST6000NM0034 drive, I have found firmware from Seagate to flash to E005 or E0G5, when I try this I get this response;
Write buffer cmd: 3b 05 00 00 00 00 19 60 00 00
write buffer: Descriptor format, current; Sense key: Illegal Request
ASC=26, vendor specific qualification ASCQ=99 (hex)
Descriptor type: Field replaceable unit
code=0x3f
Descriptor type: Vendor specific [0x80]
00 00 00 00 00 00 00 00 00 00 00 00 00 00
bad field in Write buffer cdb
Can someone point me to the right post or help me with this error.
Thank you in advance.
 Post subject: Re: Stuck with a certain flashes
PostPosted: November 18th, 2020, 13:06
I'm having this exact same issue. Did you ever find a solution?
PostPosted: November 25th, 2020, 9:37
As of yet I have had no success, the LOD file from Seagate isn't giving a successful flash on these drives.
Users browsing this forum: Bing [Bot] and 4 guests
