What is the solution
Poll ended at April 14th, 2022, 9:00
how can i solve it? 100%  100%  [ 1 ]
What is the solution 0%  0%  [ 0 ]
Total votes : 1
 Post subject: Unllocatted external Hard driver
PostPosted: April 12th, 2022, 9:00
Hello everyone
I have a laptop hard disk not used for a long time,
I tried to use it through USB hard disk enclosure. the two blue lights are on but
in Management
It says unllocated
It doesn’t even show on my computer
File comment: 1
File comment: 1
 Post subject: Re: Unllocatted external Hard driver
PostPosted: April 13th, 2022, 8:07
Take out of enclosure > connect through SATA > clone it using HDDSuperClone. Your poll makes zero sense.
PostPosted: April 14th, 2022, 2:51
+1.
Then, analyze with DMDE.
PostPosted: April 14th, 2022, 11:06
Your drive has disk surface damage/degradation, which is triggering cyclic redundancy check errors (aka bad sectors).
In order to recover the files, the data has be cloned to another healthy drive.
For Do-It-Yourself methods, hddusperclone or ddrescue are ideal. Otherwise, reach out to a data recovery specialist (not a computer shop).
Users browsing this forum: No registered users and 17 guests
