 Post subject: Seagate ST1000 DM003 cant access TTL
PostPosted: October 7th, 2016, 16:08
Hi all i try to access the ST1000DM003 1TB is the terminal locked ?
and another question I also try to read the chip with the LT866CS but which chip do I need to choose ?
my idea is to read the chip of the original PCB and write it in the donor later if i got it.
so I dont need to reflow
Pleas move post if its wrong here
thank you
faithfully
serversponsor
 Post subject: Re: Seagate ST1000 DM003 cant access TTL
PostPosted: October 19th, 2016, 15:18
Sorry for the delay in the reply.
What is the exact problem with the drive ?
ST1000DM003 have locked terminal access. If you don't have the latest version of PC3K you can't "unlock" the terminal access.
Most likely your drive doesn't have a PCB issue.
If you need the data then send the drive to a data recovery firm (with PC3K).
The ROM that you will need to read/write is an 8 leg SOIC 8 that shouldbe somewhere on the PCB. Just check all SOIC8 chips and read it's marks/printing to see if they are actually flash/rom chips. You can post a picture of the PCB and i will mark the chip for you.
PostPosted: October 19th, 2016, 15:46
Hi Thank you for the reply
here are some pictures
so my idea is to read the rom with the LT866CS then write the data to a donor
so i dont need to put the SOIC8 from the old PCB to the new one (soldering(reflow)
and then try to use it.
symtomes are:
shortly clicking
hdd not regonized / even in BIOS
with another PCB it regonized and shows some GB but tis is only for test and is not clicking
so I guess its a PCB or a firmware error
I found some Infos for terminal mode there is a way to shorting some pins on the PCB to get access
havent tryed yet
thank you for help :)
