 Post subject: BGA "glue" removal
PostPosted: December 19th, 2017, 6:18
What's your take / tip on the removal process for BGA-chips that are glued down?
More often than seldom we receive cell phones that's got a seemingly impossible-to-remove-glue around and beneath the BGA-chip (sometimes around other chips as well, like TSOP, but BGA seems to be more popular), and at this time we've had to pass around 25% of the work due to the glue.
The technique I've used myself this far is a pretty good chemical solution found on Ebay/AliExpress, and a hardened steel hook to carefully scratch away the glue, but this chemical doesn't seem to work with all kinds of glues.
I'm open to learn new techniques.
 Post subject: Re: BGA "glue" removal
PostPosted: December 19th, 2017, 12:09
There are different types of underfill but the ones I've come across tend to soften up quite a bit when exposed to hot air of ~200C. Then you pick at it with special tools such as https://www.unionrepair.com/qianli-ic-chip-edge-rubber-bend-removal-blade-2-in-1.html or https://www.unionrepair.com/qianli-ic-chip-removal-blade-16-in-1.html.
Designated Fixer at home | Learn more about what I do
