General discussions, chit-chat
Phase 2 - DIY Air Purification Project @ CDRLabs
December 4th, 2015, 14:06
Hello All,
After My Laminar Bench Purchase I Am Now Wanting To Move To stage 2 of my lab filtering .I would like to design 2 Static , 2 Wall Mount And 2 Mobile Air Purification Units .I Will Go the DIY Route Because I am Not sure what Crap i Get In India .The Plan Is To Make Use Of The Following Just Like a Laminar Flow Bench
1 : Prefilter [ For Air Intake ]
2 : Centrifugal Air Fan For High Speed Air Flow
3 : Hepa/ulpa Filter In Exhaust Stage .
4 : Speed Control
The Portable Units Would Just Have Prefilters And No Hepas But They Would Be With Casters . I Have Taken Some Idea From youtube For 2 static [ Non Movable Air Purifiers ] And 2 Wall Mount Air Purifiers But i Would Add The Indian Glory To It .The Portable Once Would Be Like This
Re: Phase 2 - DIY Air Purification Project @ CDRLabs
November 29th, 2018, 3:20
2 quick questions:
- Is this True HEPA
- ozone emission or not?
November 30th, 2018, 13:06
Hi the idea is that your Cleanroom should be in room and that room should be in a room .So the outer room should have somewhat clean air ,In that case a prefilter based air purifier is good enugh for the outer room .In my case i ended up building a Wall Mounted Air purfier on two sides of the room .
November 30th, 2018, 13:46
I think you are on the right track Amarbir.
December 4th, 2018, 0:15
Great to hear that, thank you.
June 20th, 2019, 3:49
What happened with your air purifier at the moment, Amarbir?
June 24th, 2019, 13:44
brentpham wrote:What happened with your air purifier at the moment, Amarbir?
Well,
Tell Me What You Are Upto And i May Help You
