 Post subject: problem with HDD Raw Copy Tool 1.10
PostPosted: January 19th, 2018, 14:35
please check the log below
1/19/2018 12:36:38 PM
1/19/2018 12:36:38 PM * * * * * IMPORTANT: DURING THE DUPLICATION PROCESS
1/19/2018 12:36:38 PM ALL DATA ON TARGET WILL BE IRREVERSIBLY OVERWRITTEN!
1/19/2018 12:36:38 PM Source: [0] RAW ethos-1.2.7.iso [7860.5 MB]
1/19/2018 12:36:38 PM Target: [0] HP SSD S700 120GB Q0616B1 [120.03 GB]
1/19/2018 12:36:43 PM Locking device...
1/19/2018 12:36:43 PM Copying...
1/19/2018 12:39:23 PM Write Error occurred at offset 7,851,671,552 (87)
1/19/2018 12:39:23 PM Cannot write to target, aborting...
1/19/2018 12:39:23 PM Average speed: 49.0 MB/s
1/19/2018 12:39:23 PM Operation terminated at offset 7,851,671,552 LBA 15,335,296
i have tried both portable and setup version , both results in the same thing , it reaches 100% and then stops
while googling i sow that error means the source is larger than destination , but in my case the destination is 120GB , its an hp M2 SSD
i went to windows disk management and it shows that HDDrawcopy tool has created a 2 new partitions one 7.31Gb and another 11MB
i think the tool is trying to create a new partition with the same size of the ISO file but it creates slightly small partition resulting in this error
please someone help me with a solution , thanks
 Post subject: Re: problem with HDD Raw Copy Tool 1.10
PostPosted: January 19th, 2018, 14:56
Start by testing the SSD. Get something like Vuictoria and check if you can write and read/verify the entire surface of the SSD. If so erase it.
Now if you are sure that the SSD is good and you want to write the iso to it you can try with another tool.
By the way is the iso an image done from an old ddrive or is it something you should write to a DVD ?
