 Post subject: How long does it take to get a WDMarvel License key?
PostPosted: February 5th, 2018, 11:17
I purchased Saturday afternoon via PayPal and have gotten anything. I have posted on the WDMarvel about this but got nothing.
Is this typical for this program?
 Post subject: Re: How long does it take to get a WDMarvel License key?
PostPosted: February 5th, 2018, 11:48
Have not* gotten anything
PostPosted: February 5th, 2018, 16:29
I did get mine on the same day.
WDMarvel first key is necessary to log-in to the forum (and gain access to WDMarvel owners sections of the forum).
Hopefully you will get your key shortly.
Hope that you did get the lifetime license as it's very worth every $$$.
PostPosted: February 5th, 2018, 16:31
senordingdong wrote:
(...)I have posted on the WDMarvel about this but got nothing.
I will tell Vlad about this. What is your transaction ID and nickname on the forum ?
PostPosted: February 5th, 2018, 17:39
nickname (unprivlaged) is itelite
trans id 08Y13894VW6110157
Thanks I'm sure he is a busy guy.
I went with the 1 month to test a this point, but yeah no reason not to buy in for life if this goes well.
just a slow fix on a USB WD, so should go off without a hitch (hopefully ha)
PostPosted: February 5th, 2018, 17:45
WDMarvel is very worth every $$$.
I do love it's GUI and functionality. Very simple for starters and very powerfull even for pros. Of course i would love to have some SeDiv functions of it as well like the option to load SA from the drive itself (initialize from copy 0 - for example) but yet it's a very powerfull tool.
As for the slow fix instead of using the automatic function use this method instead :
http://www.hddoracle.com/viewtopic.php? ... t=60#p9874
I will alert Vlad about this issue.
PostPosted: February 5th, 2018, 17:50
Ok, i did PM Vlad about ths license issue.
Regards.
PostPosted: February 5th, 2018, 20:50
I don't have WDR at this point. Not totally sure where to get that. Can you point me in the right direction?
As far as the "deal with slow drive" function in WDMarvel. Is it not identical in result to what you describe? Not doubting you in any way, just trying to understand if does some thing different than your posted method.
Thank you as always
PostPosted: February 6th, 2018, 16:15
Just a general question. I see that there is a firmware update available for this drive. I do believe i have plenty of use time to get it updated. I am consistently getting about 10 minutes out of it before it slows to a halt.
Is there any indication from WD that is is something resolved in a firmware update? I have to imagine they would be aware of and want to stop the failures.
PostPosted: February 7th, 2018, 3:33
There “may” be a chance they’ve made some updates to the firmware but chances are NOT, judging but the young age of the drives we are still getting with same/similar issues.
In any case, a fw update would be exactly that. An UPDATE and not a REPAIR :-(
www.pcimage.co.uk
PostPosted: February 7th, 2018, 11:19
Key has been received.
I ran the update. No change other than now it also mounts a virtual CDrom with the wd software on it
PostPosted: February 10th, 2018, 10:41
Hi there !!!
You shouldn't have updated the WD drive firmware.
This is a very bad move. You should have disabled re-location first (background media scan) and then power off/on and attempt to clone/image the drive.
I did reciev a message on WDMarvel forum saying that your key was sent.
You can check my guide and instead of using WDR that is very old and obsulete use the WDMarvel to clear the re-lo list instead.
Regards.
