 Post subject: HDD Raw Copy Bootable Media
PostPosted: August 15th, 2018, 22:12
Hello Everyone,
Is it possible to create a bootable media (CD/USB) to boot from and launch HDD Raw Copy? I've tried to build a WinPE x86 based on Windows 10 kernal and had no success in launching the software. I would like to be able to launch the software from the boot media, so I can take an image of the SSD that is physically mounted to the same computer.
Thank you.
 Post subject: Re: HDD Raw Copy Bootable Media
PostPosted: August 15th, 2018, 22:22
It's a different tool, but HDDSuperClone has a LiveCD:
http://www.sdcomputingservice.com/hddlivecd
PostPosted: September 30th, 2018, 13:39
Hiren's boot CD does have a mini XP that can be used to run HDD Raw Copy tool. Also some versions of Hiren's boot do even include the tool ....
I wouldn't be using that HDD Raw Copy tool anyway .... You will be better off with something like savepart executed from pure DOS if the goal is just to clone good working drives ...
If the drive does have bad blocks you should use either hddsuperclone or ddrescue ....
