Post new topic Reply to topic  [ 94 posts ]  Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: New version of UFS Explorer
PostPosted: August 11th, 2020, 8:40
What's new in version 8.4:
* Added DeepSpar Disk Imager network terminal to 'Tools' menu;
* RAID builder dialog:
- Added virtual sector size transform to disk menu;
- Changed icons to indicate component type and read method (System/ATA/SCSI);
- Ability to load partial RAID config via this UI (when components are missing);
- Displaying drive serial number or image file path as ID for missing components;
* RAID configuration files:
- Save/restore drive read method (System/ATA/SCSI);
- Drive Serial Number is now saved to config file;
- Restore RAID config with verification and priority of drive Serial Number;
- When disk image is not found, searching it at the same location on other drives;
- URCF extension is now mandatory for RAID configuration files;
* Added error reporting for bad RAID configs when opened via general 'Open' dialog;
* Added 'Skip file' button to copying dialog (to skip individual files);
* Raw recovery:
- Added file name generation for .contact, .vcf, .fb2 files;
- Recovery of name (Original/Internal) and build date from Windows executables;
- Adjustment of file size for EXE/DLL/SYS files to match size of sections and signature;
* Speed-up of properties (preview) extraction for Windows executable files;
* In disk list: change drive icon to ATA/SCSI when drive works with custom method;
* Added ability to change read method via storage properties;
* In 'Open device': devices are re-sorted by drive number.
PostPosted: August 11th, 2020, 14:28
Impressive list Iurii, thunbs up 8)
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: September 3rd, 2020, 5:08
What's new in version 8.5:
* Added Adaptec RAID6 to 'Visual mode' of RAID Builder;
* Added 'Grid pattern' view mode to RAID Builder:
- Conversion of standard patterns to grid (including delay, shift etc.);
- Visualization of custom patterns created with RDL;
- Active pattern cell corresponds to hexadecima viewer position;
- Stripes naviagtion using pattern grid;
- Support of both vertical and horizontal pattern view modes;
* Added 'Entropy report' (histogram) to 'Reports view' of RAID Builder:
- Shows entropy histogram of all readable storage components;
- Configurable x-scale, y-scale and y-adjustment of the histogram;
- Supports sigma-smothing of histogram values;
- Custom histogram colors;
- Support of dynamic report reconfiguration when drives order is changed;
- Pick address location from report picture to navigation in hexadecimal viewer;
* In disk imager: handle BSY/DRQ status as a reason for retries and pausing imaging;
* Reworked procedure of deleted files recovery from EXT3/EXT4 file systems;
* Updated format of 'scan status database' and 'virtual file system' files;
* Photo viewer adopted for new digital camera raw formats of:
- CANON EOS-1D X Mark III, EOS 250D; Fuji GFX 100, X-Pro3, X100V, X-T4;
- Nikon D780, Z5; Pnanasonic DC-G100, DC-TZ95, DC-G90, DC-G95, DC-GX880;
- Sony DSC-RX100 VII, a7R IV, a6100, a9 II; Olympus TG-6 etc.
PostPosted: September 25th, 2020, 19:34
What's new in version 8.6:
* Added tool for finding RAID6 Reed-Solomon code multiplicator coefficients;
* Added tool for unwrapping eCryptFS passwords from wrapped password files;
* Support of password unwrapping from Synology 'key file' backup and legacy keystore;
* Added address translation from component to RAID location for RAID0/1/1E/3/5/6/Span;
* Enabled support of address translation from disk-on-disk storage to parent;
* Raw data comparison tool:
- Added ability to change components order;
- Added tool for address translation to component;
* Indication of file chunk addresses on Btrfs file system and its scan result;
* Indication of inode offsets on Btrfs file system;
* Fixed rare crash bug that was happening at the end of storage scan;
* Fixed bug of failure of writing data to disk (modifying content) in SCSI mode;
* Modified handling of APFS metadata damage to show more structure when tree is damaged;
* Fixed several bugs with Btrfs file system scan;
* Raw recovery:
- 'Title' is now recovering as file name for .html and .wpl formats;
- Added title and date extracton from ODT/ODS/ODP document files;
- Fixed crash bug on invalid exe-file data.
PostPosted: September 25th, 2020, 19:39
Nice job Iurii :good:
PostPosted: October 19th, 2020, 15:18
What's new in version 8.7:
* Drobo BeyondRAID:
- Reworked BeyondRAID internal reading procedure;
- Fixed bugs that caused errors in degraded RAID virtual reconstruction;
- Added recovery with two missing drives of dual redundacy configurations for 4-8 drives;
- Simplified RAID builder dialog for BeyondRAID configuration;
* ExFAT scan procedure:
- Additional procedure for finding previous file system align after storage re-partitioning;
- Reduced number of 'found file systems' with wrong align;
* NTFS: enabled direct file system access when DATA attribute is damaged;
* HFS+ file system:
- Fixed few bugs preventing detection of several partitions during single scan;
- Reduced memory use by better isolation of files between found file systems instances;
* Fixed several problems in software versions for macOS:
- Fixed crash bug in copying procedure when popup dialog window have to appear;
- Fixed rare bug causing dialog sheet to 'stuck';
- Fixed problem of displaying some auxilitary UI captions;
- Added software notarization for macOS version 10.14 and later;
* Added S.M.A.R.T. monitor window:
- Support of most important S.M.A.R.T. attributes for ATA drives (under all OS);
- Disk temperature and percent of spare space usage for NVMe drives (Windows);
- Disk temperature and growing list (G-List) size for SCSI drives (Windows, Linux);
- Manual or automatic data refresh;
- Function to enable/disable S.M.A.R.T. monitoring on ATA/SATA drives.
PostPosted: November 11th, 2020, 5:14
What's new in version 8.8:
* Added decryption of TrueCrypt/VeraCrypt-encrypted storages:
- Support of both password and file-based encryptions;
- Support of AES, Serpent, Camellia and Twofish decryption algorithms (no chains);
- Support of RIPEMD160, SHA-1, SHA-256, SHA-512 and Whirlpool hash functions;
- Tests automatically standard/hidden and main/backup header locations.
* VMFS file system:
- Added automatic assembly of multi-extent and big (over 16TB) volumes;
- Fixed bug of VMFS/VMFS6 scan when partition start is not aligned properly.
* Added 'Drobo BeyondRAID Assistant' tool (Wizard mode):
- Selection of any disks for analysis (including spare, replaced etc.);
- Quick asynchronous scan for lost metadata;
- Caching of scan results to speed-up work with multiple configurations and/or volumes;
- Support of 1..8-disk RAID sub-configurations built on any number of disks in set;
- Automatic, semi-automatic and manual drive numbers assignment.
* Reworked usability of checkboxes on tree view of 'Explorer' UI;
* NTFS file system:
- Added procedure of files recovery using $LogFile content;
- Added indication and blocked copying of non-synchronized files from OneDrive;
* Enabled following symbolic links in Explorer (when possible);
* Fixed bug with copying error when source to target is copied root to root;
* Added displaying of metadata files to result of indexing of HFS+ file system.
PostPosted: December 3rd, 2020, 10:39
What's new in version 8.9:
* Flash-Friendly File System (F2FS) support: access, map of used blocks, scan;
* Support of Enmotus FuzeDrive storages;
* Added function of clearing 'read status map' for certain storage types:
- Function is added to drive/partition context menu of supported storages;
- Implemented clearing 'read status map' for SDLSP files, including 'on-demand images';
* DeepSpar disk imager:
- Implemented and added 'Clear Map' function (in disk context menu and on disk imager tab);
- In disk imager: added option for fast background imaging under full control of DDI;
- Added DDI Activity Monitor tool (available through disk context menu);
- Added DDI Terminal tool invocation to disk context menu;
- Opening the same terminal now activates exsting window (if present);
- Title of terminal window now includes DDI ID, project ID and IP;
- Fixed bug with read errors caused by unexpected UDP packets arrival.
* Decryption of BitLocker volumes:
- Show 'Recovery key identifier' in password entry dialog to identify recovery key;
- Support of incomplete encryption/decryption (Windows 7-10, Server 2008R2-2019);
- Indication of partitions with incomplete BitLocker encryption/decryption;
* In Explorer dialog:
- Files copying now hides preview/hexadecimal viewer panel to release space for log;
- 'Preview' button on toolbar now have sub-menu to open hex panel or last copying log;
* Added 'read' support of UDF file system from partitions with 512/4K sector size;
* Fixed problem reading ATA SMART under 32bit Windows;
* Under Linux/Mac: restoring 'owner' RWX permissions for copied files (when available).
PostPosted: December 22nd, 2020, 9:45
What's new in version 8.10:
Added support of LUKS2 decryption:
- Supported transform functions: pbkdf2/argon2i/argon2id;
- Supported hashes: SHA-1/SHA-256/SHA-512;
- Supproted encryptions: AES/Serpent/Twofish/Blowfish (XTS or CBC);
Rework of ZFS file system scan procedure:
- Now works on any supported ZPool configuration;
- Added scan support of Oracle RAID-Z mirror-style metadata;
- Better recovery of file system structure, including names/structure of lost datasets;
In Explorer dialog of scan result:
- Function of manual renaming files and folders via 'Properties' dialog;
- Adjusting (reducing) file size via 'Properties' dialog;
- Deleting unrequired files from scan result (with 'Del' button; support of files only);
Direct access to ZFS file system:
- Changed displaying of datasets to 'natural' tree structure instead of flat list;
- Fully reworked assembly of ZPools to support multiple RAID-Z VDevs and mirroring;
Disk imaging with map (used/free space, selected files etc.):
- Added 'policy' of combining segments for map optimization (to ignore small 'gaps');
- Added 'Evaluate fragments' tool for assistance with selection of 'combining policy';
In file copying procedure:
- Added 'Skip all' option to 'Failed to save..' dialog of current copying session;
- Changed to 'smooth' total progress and added indication of 'remaining size';
- Added displaying of 'Stated time' and 'Completion time estimate' values.
PostPosted: December 22nd, 2020, 16:27
Very cool!!
PostPosted: January 15th, 2021, 10:57
What's new in version 8.11:
* Added iSCSI Target Server for mounting storages to operating system:
- Setting up of any storages or partitions as iSCSI targets (from context menu);
- Read-only iSCSI access locally or over LAN (no authentication);
- Support of Microsoft iSCSI Initiator (Windows), open-iscsi (Linux), globalSAN (Mac);
- Trial limitation of target size is set to 5368709119 sectors (2.5TB);
* Btrfs: fixed issue with assembly of multi-device volumes for direct access;
* ReFS3 file system:
- Fixed problem with incorrect behavior of pause->preview->resume scan sequence;
- Updated 'read' and 'scan' modules to support the latest file system version;
* Handling of disks with reported non-standard big sector sizes (4160, 4176 etc.);
* Extended file system object attributes (custom named properties):
- Reworked procedure of restoring attributes when copying data (Windows, Linux, Mac);
- Added function of listing attributes and displaying of their content in Explorer;
- Reworked support of Apple attributes for HFS+ and APFS file systems;
- Changed format of SSDB and VRFS files to support associated attributes (out of tree);
- Reworked scan procedures of HFS+/APFS to store attributes in new format;
- Added support of NTFS alternative data streams as 'named attributes';
- Added support of Linux xattrs on Ext2-Ext4 and XFS file systems;
* XFS file system: added support of multi-block directory clusters;
* ZFS file system:
- Added support of file system block sizes up to 1MB (for OpenZFS);
- Added support of undelete after 'long deletion' of big files (multi-transaction).
PostPosted: January 16th, 2021, 3:08
iSCSI target service allows mounting of any storage object to operating system as a virtual SCSI disk and complete data recovery operations with system or third-party software (copying files, decryption, decompression etc.). Tested with mounting file systems to Windows, Linux and Mac. Also virtual disk can be processed with third-party software (tested using R-Studio).
PostPosted: February 4th, 2021, 12:52
What's new in version 8.12:
* Updated RAID builder dialog:
- Added support of selecting multiple components for 'bulk operations';
- Support of 'Move', 'Remove', 'Edit size' and 'Revert size' via 'bulk operations';
* ReFS3: fixed several compatibility issues (support of resident and named pointers);
* Added 'metadata objects filtering' functions to file copying procedure:
- Pre-defined types of metadata files and folders can be optionally skipped;
- Procedure can be enabled, disabled and configured via software 'Settings';
- 'Save selection (advanced)' function has option to override default settings;
- Pre-defined metadata for NTFS system files, Synology folders, Apple resources;
* File saving conflict (duplicate file action):
- In default pop-up window added option to abort copying;
- Added pre-configured setting to overwrite file 'if new file is modified later';
* NTFS: support of more scenarios for file information recovery from LogFile;
* FAT16: fixed problem with recognition of root folder in non-indexed full scan;
* ExFAT file system scan:
- Processing of tails of overwritten folders (in full and quick (indexing) scans);
- Result is filtered to remove junk objects that may appear from damaged folders;
* Fixed bug with file system structure recovery when intermediate folders are lost;
* Fixed read/quick scan of HFS+ with 'overflowed' fragmentation of Catalog File;
* Software version for macOS:
- Adopted and optimized GUI to specifics of Big Sur (macOS 11);
- Software optimization for better translation to ARM64 (Apple M1) via Rosetta.
PostPosted: March 2nd, 2021, 10:09
What's new in version 8.13:
* Added function of access to network disks via built-in iSCSI client:
- Full support of discovery and communication with UFS Explorer iSCSI Targets;
- Support of third-party SAN/iSCSI targets (require multi-host/cluster support);
- Authentication, multi-LUN targets and single-connection mode are not supported;
* iSCSI Target server: added function to attach/detach local disk (under Windows);
* WD MyCloud storages:
- Added indication of MyCloud volumes;
- Added support of newer metadata format (version 156);
- Type of file system transformation is set for them as 'MyCloud' by default;
* Added indication of sector/cluster number on hexadecimal viewer;
* Added separate field for copyable sector indicator to hex data inspector;
* Fixed bug reading partially encrypted B-tree on APFS;
* APFS: fixed B-tree reconstruction bug in scan procedure;
* HFS+: fixed bugs reading of damaged B-tree;
* XFS: fixed bug reading named attributes;
* ZFS: fixed bug with recognition of lost simple volume partitions during scan.
Users browsing this forum: No registered users and 6 guests
