Post new topic Reply to topic  [ 165 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9  Next
 Post subject: Re: New version of UFS Explorer
PostPosted: July 25th, 2021, 11:21
Paradog84 wrote:
Iurii wrote:
What's new in version 8.16:
Added support of Intel IMSM NV Cache (SRT, Optane Memory) technology;
Could you explain how to combine the 2 storages?
- connect the original or image of the main storage and cache
- on the cache (flash) will be a partition with a "characteristic icon". in the context menu of the partition there will be an item "Build Intel Cached (Optane) Storage".
- if everything is OK - it will automatically build a new virtual disk
PostPosted: September 20th, 2021, 7:12
What's new in version 9.0:
* Scan now has option to save status periodically (with predefined time period);
* Folders in scan result now display contained objects capacity;
* Explorer now highlights lager files/folders in scan result with percent bar;
* Color differentiation of existing and scanned file systems in Explorer;
* Data saving now can be scheduled as number of steps in priority order:
- Added 'Create batch copying task'/'Add to copying task' tool to context menu;
- Task can be aborted with possibility of resumption from aborted step;
- Common task copying log with logging of task step events;
- Task manager dialog to re-order, remove or configure steps (enable filters etc.);
* Added 'Quick scan (index)' tool to context menu of valid ('green') file systems;
* When empty or damaged FS is activated, there is a choice to browse or to scan it;
* Activation of partition with no file system now activates 'scan' dialog;
* Support of hard links on NTFS, APFS, HFS+, Ext, F2FS, Reiser, UFS and XFS;
* Added automatic deduplication of duplicate hard links:
- Hard link to file is restored as hard link on target storage;
- If target file system doesn't support hard links, software creates copy of file;
- Hardlinks to HFS+ folders are restored to special location and linked with target;
- Links to folders are established with hardlinks (on HFS+) or with symlinks;
- If target file system doesn't support links, software fails to process such folders.
* Added support of duplicate file/folder hard links in scan result;
* NTFS scan procedure now processes NTFS indexes and thus hard links;
- In 'quick scan' this function is disabled by default;
* APFS direct access:
- File system state is now loaded using the latest generation of stored superblock;
- Added support of file system snapshots, including 'local' and 'backup' Time Machine;
- Loading of file set is postponed until it is first used (for performance reasons);
* APFS scan:
- Indexing of APFS optionally includes snapshots (enabled by default);
- Better structure recovery and finding of lost snapshots in full scan;
- Added support of symbolic links;
* HFS+ scan: added support of hardlinks (including Time Machine);
* Changed format of SDLSP files to version 3.
* Added support of flat-sparse image files (set of chunks with missed fragments);
* Added tool for saving on-demand disk image files (imaging tasks):
- Support of imaging to flat, flat-sparse and sparse (SDLSP) disk image files;
- Support of imaging (clonning) to another disk;
- Using of built-in defect map for SDLSP and external defect map for other targets;
- Save/restore of task configuration (.uitask) files
- Support of 'imager' interface and background (asynchronous) imaging;
- Task control panel with map of defects and with activity indication;
- Map of defects can be cleared in given region (all states or only defects);
- Detailed configuration of imaging parameters (two-pass imaging, timeouts etc.)
- Quick switch of pre-configugured and customizable imaging tiers;
* Support of reading S.M.A.R.T Log pages of SATA drives;
* Added indication of file status (validity) information for scan results:
- Indication is enabled by default; it can be disabled via 'Explorer' settings;
- Verification if file start matches to data of known and valid type;
- If defects bitmap is available, optional check if file is imaged;
- Tool to enable/disable/configure file status indication in Explorer;
* Option to save 'only good files' when status indication is available and enabled;
* In Explorer, added ability to stop reading content of big folders;
* Added decryption of BitLocker and APFS encrypted volumes [UFSX Std/RAID/Net]
* Added tool to re-assign file extensions basing on content (for CHK files etc.);
* Preserving 'Hidden' and 'System' flags on copied files (Windows version);
* XFS access: fixed problem with mixed Intel/Standard short folder metadata;
* XFS scan: fixed few major bugs with structure recovery in full scan;
* NTFS access: fixed issue displaying of multiple hardlinks from the same folder;
* NTFS scan: added processing of mount points as 'folder' symbolic links;
* ReFS3 access:
- Mount points (junctions) are displayed as 'folder' symbolic links;
- In symbolic links, paths are changed to relative to support their 'export';
* Older ReFS (Windows Server 2012): fixed few bugs in scan procedure;
* ExFAT scan: support of 1MB clusters, fixed few issues;
* File removal from scan result now updates title statistics (files count/size);
* Fixed loading RAID/storage configurations when PhysicalDrive has no serial number;
* Fixed issue with long cancellation of quick scan and duplication of results;
* Fixed duplication of $LostFiles folder in scan result;
* Fixed bug in adaptive RAID5/RAID6 reconstruction;
* Fixed problem with support of ATA S.M.A.R.T via DeepSpar USB Stabilizer.
PostPosted: October 18th, 2021, 9:43
What's new in version 9.1:
* Added Drive/Bridge Security tool:
- Decryption of WD drives encrypted with JMS538E, Inic-1607E, OXUF943SE and SW6316 USB bridges;
- Support of key block detection both on storage area and in SMART Log pages;
- Support of standard AES-256 ECB mode (also AES-128/256 ECB/CBC/XTS modes, depending of chip);
- Unlocking of password-locked WD drives (no need to install and run WD Security software);
* Defects emulation by pattern recognition in 'read ahead' mode now uses cache (for speed);
* Support of macOS ".sparsebundle" disk image format (open as disk-on-disk storage);
* Microsoft Data Deduplication:
- Software now automatically asks to open and enable MSDDD when file system is opened;
- Fixed support of big (over 1GB) files deduplicated with Windows Server 2012/2012-R2;
- Fixed issue with opening files from relocated segments;
* Decryption of encrypted Apple DMG disk images (version 2/'encrcdsa' format);
* Fixed bug with data caching in hexadecimal editor;
* Recovery of lost address translation leafs in Btrfs scan (for correct deleted data recovery);
* FS with address translation (Btrfs) is now supported for 'status indication' in Explorer;
* File and Folder hardlinks deduplication is now made optional;
* Fixed few issues with disk imager (corrected number of retries, read block size etc.)
PostPosted: November 21st, 2021, 5:38
What's new in version 9.2:
* 'Transform sector size' tool is extended with options to switch between 512/1K/2K/4K sectors;
* Added decryption of encrypted VMware VMDK virtual disks (encrypted VMs for Windows 11 etc.);
* Added decryption of compressed Apple DMG disk images encrypted with version 2/'encrcdsa' format;
* Write support for VHDX virtual disks (file creation and modification);
* In 'Imaging Task' interface:
- Added VHDX as target file format option;
- Optimized target format selection UI;
* Added VHDX as target file format option for Disk Imager;
* 'File mask' operations ('search' etc.) now all support multiple values with semicolon as delimiter;
* Raw recovery and tool for re-assigning file extensions are extended with more types;
* Fujifilm RAW photos format (RAF):
- Added extraction of file size, camera 'model name' and 'date taken' in raw recovery;
- Fixed issue with file separation to 'preview' and 'tiff' when it is detected by content;
* MacOS HFS+ file system:
- Enhanced procedure of damaged file system reconstruction and deleted data recovery;
- Fixed issue with direct access to highly fragmented file system;
* Fixed several issues with Btrfs file system scan.
PostPosted: November 21st, 2021, 8:44
BTW Guys ,
This was done by one of my cases ,It was a XQD card and the card would show proper partition and file and folder structure ,But after cloning in UFS the cloned image would behave in a different manner ,Then using this function and transforming we could see file and folder structure properly
PostPosted: December 14th, 2021, 6:24
What's new in version 9.3:
Added experimental support of Synology SSD write-cache:
- Recognition and indication of SSD cache partitions;
- Applying latest cached data from SSD 'as a delta' to the 'base' volume;
Added decryption of drives from WD MyBook with JMS561 bridge chip;
Fixed several issues with opening files, deduplicated using Microsoft Data Deduplication;
Under Linux, added 'unlock' function for WD drives, locked with WD Security;
File status indication in Explorer is extended with 'zeroed' (bad) state;
Source sector size is now preserved for image files, saved to VHDX and SDLSP formats;
In Linux software version:
- Added proper identification of SCSI/SAT drives to support drive serial numbers etc.;
- Added support of SMART monitoring for SCSI/SAT-attached drives;
Linux LVM2 logical volumes:
- Added indication of logical volume ID in partition properties;
- Fixed issue with recognition of 'long' (64K) binary metadata;
- Fixed issue assembling multi-segment logical volumes on 'fake' (single-component) mdadm RAID;
For manually defined partitions added recognition of known metadata at defined location;
Reworked FAT/FAT32 quick scan/indexing procedure for better support of damaged folders;
In embedded file viewer:
- Added support of HEIC/HEIF photo format (Canon R5/R6, Apple products etc.);
- Added decoding of Fujifilm 14bit 'packed' RAF format (models X-A3, X-A7 etc.);
- Added decompression of Fujifilm compressed RAF format (models X-T2, X-T3, X-E3, X-H1 etc.);
- Defined configurations for many other raw photo formats.
PostPosted: January 17th, 2022, 8:30
What's new in version 9.4:
* Added experimental support of QNAP SSD write-cache;
* Implemented integrated management of raw recovery rules:
- Reworked storage schema for custom raw recovery rules;
- Added GUI that shows full list of custom and built-in raw recovery rules;
- Implemented simplified interface to create/view/edit user-defined rules;
- Built-in editor is set as priority source of custom rules for scan;
* Added support of BitLocker decryption using external keys from BEK-files (with no TPM);
* Update to S.M.A.R.T monitoring/log pages reader tool:
- Reading of both GP log and S.M.A.R.T log (when possible);
- Fixed issue with indication of 'seek error count' when it includes seek statistics;
* Added automatic assembly of APFS Fusion drives;
* Added indication of encrypted APFS volumes and volume decryption states;
* ExFAT scan: fixed issue with recognition of previous cluster size after format;
* Implemented ZSTD compression and enabled its support for ZFS and Btrfs file systems;
* F2FS file system: added support of 'extra attributes' flag.
PostPosted: February 15th, 2022, 6:12
What's new in version 9.5:
Action for activation of partitions with no file system now can be configured;
Disk Imager:
- Rework (optimization) of configuration GUI;
- Fixed issue with attempting 'multi-sector retries' on defect blocks with 'system' read procedure;
Added setting of file system 'read policy' for storages with defect blocks:
- Enabled support of 'read policies' for FAT, FAT32, ExFAT, NTFS, ReFS, Ext, XFS, F2FS file systems;
Added Export/Import function for user-defined raw recovery file types:
- Selective export to own XML-based file format for backup or selective restore on different PC;
- Partial support of importing user-defined rules in some third-party XML formats;
Optimized 'Refresh' procedure; scan of logical drives is now made optional (by default it is 'on');
DeepSpar USB Stabilizer/Guardonix:
- Added recognition of devices with no media or when it is not powered on;
- Added power control and support of driver configuration;
ExFAT scan: added processing of CheckDisk .CHK files (when possible), fixed few more issues;
Raw recovery scan: found and fixed 'scan stuck' issue;
Update to S.M.A.R.T monitoring tool: added 'SSD life' indication and support of SCSI Log Sense;
Added indication of storage device type and rotation speed for HDD.
PostPosted: February 15th, 2022, 9:27
List seems to be comprehensive & unending,
what about costing ? Which basic version supports all these functions and what is minimum pricing for all these functions
PostPosted: February 15th, 2022, 14:18
Most of the features of update 9.5 are implemented for all editions of the program, including the cheapest.
PostPosted: February 16th, 2022, 0:56
PM sent... :idea:
PostPosted: March 2nd, 2022, 6:06
I see in v9 hidden and system flags are retained on file extraction by default. (i.e. Folders/files still have the hidden attributes, like AppData). Is there an option to turn this function off, so that files do not have the floags retained (as per UFS v8 and before)?
Best regards,
John
CDR - Manchester Data Recovery Services
0161 408 4857
http://www.cheadledatarecovery.co.uk/
PostPosted: April 11th, 2022, 7:37
What's new in version 9.6:
Updated function of opening LVM thin-provisioned volumes:
- Added interface to choose from volumes, defined in text configuration;
- Support of QNAP thin volumes implemented via Tier/Thin technology (tiering is not supported);
- Support of segmentation for thin-provisioned volumes;
- Opened volume now contains proper LVM ID, name and Unix-path;
Added support of WD Apollo 'cloud storage';
Added activity monitor for DeepSpar USB Stabilizer/Guardonix;
USB Stabilizer/Guardonix configuration: added option for 'Auto-repower by UFS Explorer';
Disk imaging with DeepSpar USB Stabilizer:
- Added explicit configuration of re-power options for read timeout and read errors;
- Error recovery after 'storage loss' now includes re-power cycle;
General disk imaging:
- Fixed issue with handling error of creation of plain disk image file;
- Fixed support of 4GB image chunk size on FAT32 target file system;
Restoration of file/folder attributes (hidden flag, permissions etc.) was made optional;
Mac software version now comes with native Apple Silicon CPU support and requires macOS 10.15 or later.
PostPosted: April 11th, 2022, 8:07
I'm happy to see that you are still okay, @Iurii.
PostPosted: April 11th, 2022, 12:45
Hello, I hope you are well in this difficult time.
I just updated UFSExplorer Pro, thank you very much.
You can create a progress bar it indicates the percentage of transferring the data and the time to finish transferring it ?
it's easier to monitor the transfer
Thank
Sorry from my English
PostPosted: April 11th, 2022, 14:04
You mean while saving?
That's already possible. You have to change the option.
ACELab partner
PostPosted: April 12th, 2022, 8:59
Hi PClab
Thank :D
PostPosted: April 12th, 2022, 9:04
Hello
I have problem to transfer Libary folder from Photo software into Mac Os hard drive, Libary Photo folder is 120 GB. UFS Explorer Pro lost 2 days but cannot finish transferring this file.
I used my Imac, I transferred this file, it only took 3 hours.
Do you have the possibility to transfer the Libary Photo folder faster in UFS Explorer Pro ?
Thank
PostPosted: April 17th, 2022, 6:53
hvd wrote:
Hello
Thank
- it's advised to run quick-scan of the file system to prevent opening files each time from the file system metadata on disk (most time is typically used to "open" a file from file system)
PostPosted: May 12th, 2022, 7:16
What's new in version 9.7:
Linux LVM recovery module:
- Added 'address translation' of found text configurations to the base storage;
- Found text configuration now can be displayed with embedded viewer;
Added basic support of LVM thin-provisioned volumes (Linux only) via 'Find LVM' tool;
In Disk imager:
- Added option to shut down the source after completion (when power control is available);
- 'Entry name' field for EnCase format now can be customized (by default is the same as file name);
Reworked operations with defect maps:
- Updated 'map loader' GUI (more obvious configuration, added map preview function);
- Software now enables file-based maps (when possible) to speed up loading and reduce memory usage;
- New type of storage object with applied map now supports indication of imaged/defect/free spaces;
Fixed some reported bugs/issues:
- In hex viewer: incorrect base position for 'big block search', loss of colorer function for cached data;
- File system module: silent crash bug with bad F2FS;
- Handling of soft-defect blocks: extending of file map to whole block in scan result;
- LUKS decryption: using of SHA512 for hash function caused problems with decryption;
- Some minor GUI-related issues (under Windows OS).
Users browsing this forum: Google Adsense [Bot] and 56 guests
