HDD GURU FORUMS http://forum.hddguru.com/ |
wxHexEditor Hex and Disk Editor tool http://forum.hddguru.com/viewtopic.php?f=7&t=21114 |
Page 1 of 1 |
Author: | EUA [ November 12th, 2011, 21:17 ] |
Post subject: | wxHexEditor Hex and Disk Editor tool |
Hi All, I made another hex editor, wxHexEditor, wanted to mention here. It's free and also open sourced. It's working on Windows, MacOSX and Linux. You can open files and also devices with it. It allows to open up to 2 exabytes. I think some of your like that. Specially Linux users since there is no good disk editor at Linux that could open multi-gigabyte devices. http://hexeditor.eu or http://wxhexeditor.org ![]() Thanks for trying. |
Author: | northwind [ November 15th, 2011, 12:22 ] |
Post subject: | Re: wxHexEditor Hex and Disk Editor tool |
This looks interesting! Good job. Will give it a try on my Linux Mint. |
Author: | Czerno [ November 27th, 2011, 15:45 ] |
Looks very nice! Thanks for making this freely available! I shall download and try the beta soon, but what I wanted to ask right now - out of curiosity - what programming language and tool chain did you choose that could facilitate such a multi-target project ? Congrats -- Czerno |
Author: | EUA [ November 28th, 2011, 3:32 ] |
Program build with C++, using GNU C/C++ Compiler. I used wxWidgets for GUI library. For building GUI used wxFromBuilder And IDE choice is Code::Blocks. My OS choice is OpenSUSE Linux but those tools has versions for Windows and MacOSX too. |
Author: | hawk_wd [ November 28th, 2011, 6:59 ] |
very good program thanks alot |
Author: | sanlima [ November 28th, 2011, 10:35 ] |
You can also read the files of MHDD 22.bin???? |
Author: | EUA [ January 9th, 2012, 22:50 ] |
sanlima wrote: You can also read the files of MHDD 22.bin???? I don't understand this. A hex editor naturally could read every file... |
Author: | hotmuon [ January 17th, 2012, 10:21 ] |
Looks promising. I'm giving it a try now. Thank you for your hard work. |
Author: | Rozik [ January 25th, 2012, 7:20 ] |
EUA, it's very helpful! Waiting for full-featured release! Good luck! |
Author: | einstein9 [ January 25th, 2012, 7:42 ] |
Rozik wrote: EUA, it's very helpful! Waiting for full-featured release! Good luck! Rozik, out of the subject, r u from armenia? |
Author: | quasimodo [ January 25th, 2012, 13:30 ] |
EUA wrote: Hi All, I made another hex editor, wxHexEditor, wanted to mention here. It's free and also open sourced. It's working on Windows, MacOSX and Linux. You can open files and also devices with it. It allows to open up to 2 exabytes. I think some of your like that. Specially Linux users since there is no good disk editor at Linux that could open multi-gigabyte devices. merhaba arkadaş, I have been looking for a good hex editor for linux, nice project ![]() |
Author: | pollys13 [ January 27th, 2012, 7:43 ] |
EUA wrote: Hi All, I made another hex editor, wxHexEditor, wanted to mention here. It's free and also open sourced. It's working on Windows, MacOSX and Linux. You can open files and also devices with it. It allows to open up to 2 exabytes. I think some of your like that. Specially Linux users since there is no good disk editor at Linux that could open multi-gigabyte devices. http://hexeditor.eu or http://wxhexeditor.org ![]() Thanks for trying. Hi, Earlier this morning I spotted your post. Please see my post in, HDD Guru under Hard Disk Drives: data recovery and repair, date January 24th, 2012, 5:02 post title How To Recover Contents Of HD Partition? My user name is pollys13 " Depending on how much of the drive, the Windows 7 format had wiped (which could be found using a hex editor), then your original drive D might be untouched. Using a utility like Partition Find & Mount, installed on a different PC, may then allow you to find the original drive D untouched on your previous drive. " Could you explain please how, I can use your hex editor to determine the amount of damaged and undamaged data on my HD? Thank you, Peter. |
Author: | EUA [ January 28th, 2012, 6:47 ] |
quasimodo wrote: merhaba arkadaş, I have been looking for a good hex editor for linux, nice project ![]() Allah'ın selamı üzerine olsun kardeş, I was looking for such an hex edıtor too but couldn't find. Than build one. Use SVN trunk and build by yourself for v0.12 There is lots of improvements. @peter/pollys13, Unfortunately, my hex editor cannot analyze your HDD automatically. It just could open you hdd. Than you could recover your files by hand, if you have deep knowledge about your FS. |
Author: | pollys13 [ January 28th, 2012, 16:54 ] |
Hi , I downloaded your program, but the help file wouln't open I'll try again. Will try to use your editor on a cloned copy of the drive. I don't think I really need to use it, but I'm curious to find out what % of data on the drive has been damaged. Wish I could be as clever as you all are ![]() Thanks. |
Author: | EUA [ March 2nd, 2012, 6:17 ] |
Hi All! I released v0.20 recently. In this release there is more HDD related features like indicating each sector by red thin line (see screenshot at first post) Also you can use "Go to" seek any sector address directly. Also have next/previous sectors button on Goto dialog. Offset panel supports LBA addressing for block devices ( "Sector:Offset" formatting ) You can save your selection as a dump to a file directly. There is multiple CopyAs format generates dumps to clipboard for easy use at code or internet, ( currently supports phpBB forum / HTML and Wiki styles also TAGS support!!) `Find Some Byte` functionality specially useful for analyzing HDD. Just skips empty regions and finds some meaningful sectors. Here is the Full change log: Code: Added OS types to program title.
Fixed Backward/Forward search/replace gauge calculation with wrap around option. Removed some unneccessary event trigging from keyboard input, speeds up cursor a bit. Automated setting offset_scroll values at HexEditorCtrl::ReadFromBuffer. Added Clear button to Search Panel. Fixed Replace doesn't update UNDO Added better formatting to checksum result. Added copy checksum result to clipboard. Removed StatusBar Cursor Offset zeros from beginning. Fixed Tag offset show broken for big offsets at panel. Fixed Keyboard move break selection. Implemented native like selection on Text Control. Fixed Keyboard selection delay. Fixed Checksum file detection on custom file picks. Fixed comparison operation for MSW Added Debug Frame for redirecting MSW stdout. (Enabled via _DEBUG_ definition.) Added "Smart Escape" feature to GoTo dialog. Now escape clears current active field. If escape pressed on clear field, closes the dialog. Fixed Go to Dialog illegal key position walking on MSW. Fixed clearing all tag/search/compare panels on close of file. Fixed default positioning of Data Interpreter Panel at Win/OSX Disabled Win Devices that we cannot open currently Search speed up, also for Unicode UTF8 search. Added OpenMP libs flags to makefile. OpenMP still req OPTFLAGS="-fopenmp". Fixed Compare operation, Stop after N match counts merged diffs as 2. Added random color Quick TAG creation without info. Fixed Offset Scroll usage for lines instead of pages. Show sectors via thin red line for Disk access Fixed Offset scroll for Win/OSX Added Previous & Next Sector buttons to GOTO dialog. Silenced some compilation warnings. Fixed parallel make. Added cancel button to Find/Replace dialog.(We don't like GNOME3) Rendering speedup. Implemented Find/Replace Dialog reverse search option. Allowed operation without offset control. Added Hex editor alone operation mode. Added Text editor alone operation mode. Added LBA adressing mode, Sector+Offset support. Fixed XORView key entry for OSX/WIN. Added Import & Export TAGs support. Added Octal offset support. Added Compare: merge sections feature. Fixed stack overflow issues on CompareDialog::Compare(). Fixed Offset Scroll usage for lines instead of pages. Fixed Notepad file selections undo/redo disabling. Added some cross-compile helper to makefile. Implemented Fill Selection function. Added Save as Dump for saving selection as a file. Added some help strings into menubar. Disabled paste operation if selection is true. Changed empty tags, now shown as Tag's Number + Offset at TagPanel. Added CTRL+G shortcut to" Go to Offset" dialog. Changed Goto Offset as Go to Offset. Changed default PREFIX to /usr/local Updated home url and mail. Implemented Find Some Bytes button to find dialog. Fixed cursor misslocation on text/hex input at end of the screen. Fixed minus sector count at at InfoPanel. Fixed XORView check on file selections. Added Hexadecimal key support at XORView dialog. Added old value memory to all dialogs. Replaced hash calculation init with for looped one. Added MD/RIPEMD/SHA/TIGER/HAVAL/CRC/ADLER/GOST/WHRILPOOL/SNEFRU checksum functions. Added OpenMP acceleration to Checksum calculation. Added Devices SubMenu categorization. Changed file progress block sizes from 1MB to 128KB. Added mhash library for checksum calculations. Dropped Hashlib++ due some licenses in included files. Implemented CopyAs Dialog remembers old values. Changed CopyAs HTML code tags with span... Added CopyAs Format WiKi and WiKi with TAGs. Added CopyAs Dialog Byte Per Line option. Added Offset/Hex/Text part options for CopyAs functions. Implemented HTML with TAGs Support. Hey this looks good! Implemented CopyAs Internet HTML and phpBB forum functions. Implemented CopyAs BigEndian support. Implemented CopyAs Text/Hex/C/C++ and ASM Added C/C++ type hex paste input. Fixed unmatched case text search. Fixed saveAs corruption due progress bar. Fixed error message typo. Fixed Compare Dialog result corruption for bigger than MB files. Fixed slow ASCI Text find. Added speed indicator to search progress gauges. Added speed indicator to hash progres dialog. Fixed File comparison dialog error for < 1 MB files. Fixed MacOSX File:Quit menu bug while file was open. |
Author: | av8orancz [ April 17th, 2021, 14:45 ] |
Hi, I've just run into the excellent wxHexEditor program and want to say "thank you". I would like to also mention a preoblem I am encountering on Windows 10 with version 0.24 Beta (yes, Beta, I know..., but it has 2012 date on it!) Essentially, whenever I try to "Open Disk Device", it comes back with "Device is not mounted" error, followed by "File cannot open." Any words of advice? |
Author: | fzabkar [ April 17th, 2021, 17:26 ] |
https://sourceforge.net/projects/wxhexeditor/ |
Page 1 of 1 | All times are UTC - 5 hours [ DST ] |
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group http://www.phpbb.com/ |
