Post new topic Reply to topic  [ 84 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: If you are planning to buy SHT / SHTR from "USSTO" ...
PostPosted: April 3rd, 2017, 14:09
What I loved the most so far was this ...
:shock: :shock: :shock:
And te guy even called me freak ....
PostPosted: April 3rd, 2017, 21:55
You do everything like a woman
Spread out Online correspondence
I will not answer you until the day when you do an update
But you keep writing about me different crap
Waqas Ali
I stop thereafter
When the spildite stop writing about me
PostPosted: April 4th, 2017, 20:25
Spildit
Once again I tell you and all
Who has a problem with the update
Let the connection with my agent
We will solve the problem within 3 days
PostPosted: April 5th, 2017, 13:38
Spildit wrote:
lcoughey wrote:
The best I can tell, Spildit is the only user of this software and tends to speak quite highly of these "Jimmy Joe" data recovery tools that he plays with. So, it makes no sense to me why the author of the program refuses to provide him with updates that he paid for, even if it was purchased through a reseller.
Up to now, there were several positive threads about this software on his forum. I never heard of this software and only knew existed because of Spildit. I doubt that I would have purchased HRT anyway, but I can assure you that the response of the programmer is enough to deter most everyone on this forum (I assume) from ever wanting to invest into it, which is a pretty big part of the professional data recovery community.
Thanks for the post. I just want to make clear one thing, this software is SHT/SHRT and it's a exclusive Samsung tool with simmilar functions to PC-3000 Samsung tool. This tool is made by USSTO and it shouldn't be confused with BVG HRT that i allways use and talk about.
BVG HRT is hardware card based and is a complete set of tools + data imaging/extractor like PC3K. This SHT/SHTR is a software only tool to work wih Samsung drives only.
Regards.
Well,
I would love to test this tool against pc 3000 and give a fair comparison
PostPosted: April 5th, 2017, 13:56
retribut wrote:
Spildit
Ok.
I can confirm that your agent did solve the problem for me :
I do have the update now. For me it's solved. No more problem.
PostPosted: April 5th, 2017, 15:48
Good Luck Spildit
PostPosted: April 12th, 2017, 17:58
retribut, hello retribut,, please you can help me on activacion from SHT ?? i have down version
SHTv4.0.9 Demo,, i need active it, or you can send me old version uor?, can you send email juniocruz02@gmail.com
wait you my friend
PostPosted: April 13th, 2017, 13:18
wait you my friend
Goes without saying .... you would have to pay ...
But if all you need is clear SMART then you don't need to pay ....
:mrgreen: :mrgreen: :mrgreen:
PostPosted: April 13th, 2017, 20:32
hello,,what i then do to clean smart? the program SHT DEMO no acept option clear smart?
for samsung i can use hyperterminalXP? F3T> commands ??
it pin out is correct?
i have conected on terminal port 38400 and 57600 but i no get F3T> line,, only appaer ENG> line
is possible to clear?
PostPosted: April 13th, 2017, 23:38
well the Baud Rate of 57,600 is obviously right and 38,400 wrong.
F3 is for Seagate.
maybe start reading here... https://www.data-medics.com/forum/samsung-data-recovery-f28.html especially the commands
PostPosted: April 13th, 2017, 23:53
friend, your hdd need burn in test
PostPosted: April 14th, 2017, 7:51
thank much,, ...
means what burn in test?? i only want to clear smart without pay for any program,, no money...
data-medics.com i find it:
BT - switches from ENG> to BOOT> level for ROM downloading
Esc Key - switches from ENG> to DBG> debug mode
DBG>GO - switches back to ENG> level
ENG>HE - lists all available commands for the drive
ENG>RT - soft reset drive
ENG>SD - spin down
ENG>SU - spin up
Please feel free to post below anything else you know.
it are commands correct? and to clear smart read?? sorry I not understand much about this... 8)
i world to Ask you because all my HDs Is not recognized,,, I start the MHDDv4.6 the port8 just appears LBA0 and does not scan F4 to remap...??
please what i do to recognize? LBA0 from samsung WD and seagate ....
PostPosted: April 14th, 2017, 12:46
Heads are dying.
You will need a new drive.
PostPosted: April 14th, 2017, 16:50
yes Dear more how i clear smart samsung? you said:
(But if all you need is clear SMART then you don't need to pay ....)
MHDD no recognize my seagate ...
clear mean to use for commands?
PostPosted: April 14th, 2017, 17:30
VSC by ATA and NOT by terminal.
Of course drive must report RDY by ATA first ...
My guess is that you don't have IDE compatible set on BIOS or MHDD is not picking the correct drive.
If SHT DEMO can see the drive then you can use SHT ATA terminal.
At any rate that will not "save" the drive or "fix" it for data recovery ....
If you need the data you will need professional data recovery services and not regular computer repair shop work ...
Also if HD Tune can see the drive and SMART then MHDD should be able to see the drive as well if set correctly ...
PostPosted: April 14th, 2017, 18:31
well i use G41-mainboard-775 i put HD how Primary and secondary SATA, no is slave,,. i think that MHDD4.6 no work on slave? But I'll confirm this and put the result ...
more I'm really interested In your answer about samsung,,and i no know what mean VSC,RDY...For a beginner and difficult to understand,, :roll:
1 - you said to use demo SHTv4.0.9? so i can use Terminal into SHT? ATA where is it option to start ...???
work on ATA register?
I see this post I have to do this?
http://www.hddoracle.com/viewtopic.php?f=19&t=1757
Use the following VSC - DE 00 01 4F C2 A0 B0 :
i do it?
2 - ????
PostPosted: April 14th, 2017, 19:30
It will NOT help you out to recover your data.
Try to clone/image the drive with ddrescue/hddsuperclone if the drive can still be detected by the BIOS/OS.
If you still want to clear smart by VSC you might need to take care of A-list first...
PostPosted: April 14th, 2017, 22:14
Perfect thank much ... can send me MP to tearch me do A-list firt? or you can post here? how to clear List ..
So hddsuperclone is to linux ... i want only clear samsung later will post about westerdigital and seagate on other topic .. at moment only my samsung is turn ON,,WD and seagate is clicking recognize how LBA0 on mhdd.
:idea:
PostPosted: April 14th, 2017, 23:22
See http://www.hddoracle.com/viewtopic.php?f=116&t=197
PostPosted: April 15th, 2017, 7:45
then need samsung Pro Tools ? SRT? to clean A-LIST and fix LED-A problem? SRT to "fix" the SA
- Go to "Defects List", "Clear G-List" and "Clear G-list 50".
- You might have to Clear SMART too, so do it; "Actions" - "Clear S.M.A.R.T." .
- Power off and on the drive. The firmware issue should be solved.
where i download it? send by MP?
please
