 Post subject: Question about Victoria
PostPosted: June 9th, 2017, 6:34
I have one hard disk having 12gb bad sectors in beginning scanned with Victoria . If I erased the drive up to bad sectors with Victoria the remaining data is safe?
HDD 160gb
 Post subject: Re: Question about Victoria
PostPosted: June 9th, 2017, 13:44
HDD 160gb
Well,
Of course that is if you define a range and the process stops there ,But if there is any change in G and P list the translator shifts can occur
PostPosted: June 10th, 2017, 5:08
HDD 160gb
NO !!!
:evil: :evil: :evil:
If you need the data image the drive and if possible use a hardware based sollution.
If your "bad sectors" are caused by damage to the platter you might end up killing the heads if you keep on reading/writting the bad spot and if the drive is getting that many bad blocks then there are no guarantees that the other part of the platter (containing data) will not get damaged as well very shortly ....
Also you might end up with damaged FW / drive that doesn't initialize if you end up with a G-List full of defects. Erasing with victoria will place all of those bad blocks on the G-List...
PostPosted: June 10th, 2017, 17:17
Or you can use WDMarvel to cut the bad zone and to become a proud owener of a perfect hard drive with size of about 140GB.
PostPosted: June 11th, 2017, 1:29
HDD 160gb
Hello ,
Why Are You Wasting Forum Space ,This Was Already At -> viewtopic.php?f=1&t=35453
PostPosted: June 11th, 2017, 8:36
And of course..... data will be gone as translator will shift ....
