 Post subject: hrt demo need help
PostPosted: November 19th, 2017, 19:41
hello all iam attempting to learn about ata commands..ive have used some programs such as bus hound and some other demo's but they seem to lack an true full interface after fighting with some old computers and OS i was able to get xp up and running with an copy of hrt_demo with porttalk and allowio all seems fine "thank you spildit for sharing your experience"
then once the program is up and running i click the universal button and it show secondary and offline i cant get it to connect to any drive..i have disabled the drive in device manager turn on PIO mode anything to get the drive to connect!!...if any one could give me a hint of what iam doing wrong it would be greatly appreciated!!! Thanks all!!!
 Post subject: Re: hrt demo need help
PostPosted: November 19th, 2017, 22:34
You need a motherboard able to emulate Secondary channel on SATA interface and having correct settings in its BIOS.
PostPosted: November 20th, 2017, 11:00
The device manager shows the secondary sata port and it is enabled in bios...do i need to disable to secondary in device manager so there is no conflicts?
PostPosted: November 20th, 2017, 11:03
Has anyone used an dell optiplex 360 with HRT_DEMO?...i thought for sure the MOBO was compatible maybe iam wrong!!
PostPosted: November 20th, 2017, 15:31
Ok !!! I do love HRT !!!
Start by downloading the FREE Victoria for windows and scan the ports on your system in PIO to figure out the port address for the port you want to use (have drive connected).
Once you figure out your port address you can add it to HDD.INI .
Example :
[ATA PORT]
Primary=0x1f0 0x206
Secondary=0x170 0x206
PC-3000=0x100 0x0e
HRT Card 0=0xC000 0x206
Offline=0x00 0x00
Default=HRT Card 0
- Right click on the HRT_Demo exe and select compatibility mode with win 98.
- Open command line, browse to HRT_Demo directory with cd or whatever and run allowio HRT_Demo.exe /a
Select the correct port on HRT universal utility. You can now run the ATA terminal on the DEMO.
PostPosted: November 21st, 2017, 7:58
Thank you so much Spildit once again!!...THE MAN!!..now i can stop pulling my hair out !!
PostPosted: November 21st, 2017, 15:31
:D :D :D
