Post new topic Reply to topic  [ 49 posts ]  Go to page 1, 2, 3  Next
 Post subject: Seagate expansion USB desktop 3TB Unknown device, not initi
PostPosted: February 17th, 2018, 19:03
Hi, this drive was working fine. I shutdown my laptop and on the next day when I plugged it again, windows 7-64 did not show it. Device manager shows it as unknown device, not initialized. When trying to initialize it, an error pops up saying it could not do it because a specific file was not found. Then I used victoria and it reports as a drive with wrong geometry. Diskpart does not run any task to this drive because the same error as windows 7. Then I tried several recovery software and none of them sees this drive. There is no strange sound or clicks and it is spinning. I swapped it to another Seagate enclosure and nothing happened. What else could be done to bring it back? I really don't know. If anybody could help me out on this, thanks a lot.
 Post subject: Re: Seagate expansion USB desktop 3TB Unknown device, not in
PostPosted: February 18th, 2018, 10:20
Do you need the data inside the drive or you just need to "fix" the drive ?
What is the exact model fo the drive inside the enclosure ? Do not open the drive itself.
Did you try to connect the drive dirctly to a SATA port of a desktop ? Dies the BIOS pick up the drive that way ?
Also you shouldn't be using Victoria with USB connected drives and API mode. To properly use Victoria you have to let it install it's direct I/O driver (most likely you will have problems installing it on 64 bit OS) and use PIO mode.
If data is important to you you should consider the use of a professional data recovery firm.
If you don't care for the data just buy another drive and if possible don't buy Seagate.
PostPosted: February 18th, 2018, 14:32
Ok, answering your questions here I go:
1) Yes, I need the data and Fixing it.
2) Seagate Barracuda ST3000DM001 - SN:Z1F2T04J - FW: CC45 - DATE: 13373
3) Yes I connected it directly to my desktop. Although my desktop motherboard has a BIOS of 2008, it could see the drive but with wrong capacity. Pls see attached pictures.
4) Considering the use of a professional data recovery firm is out of question. I cannot afford one. That's a backup drive and what I can figure out about it is that the MBR, Vol and FTable are screwed, that's my opinion. I'm not an expert on HDD engineering but it seems the drive ID has been fucked up.
5) Yes, I myself gave up on Seagate HDD a long time ago. This is a friend's drive unit I was using to do some backups and now I need to recover it, if that's possible. I may be wrong, but I think it can be fixed.
Tks.
PostPosted: February 19th, 2018, 15:25
Answering your questions, here I go:
1) Yes, I need data and fixing it.
2) It's a Seagate Barracuda ST3000DM001-1E6166 - FW: CC45
3) Yes I did. Although my desktop motherboard BIOS is of 2008, it could see it but with wrong capacity.
4) Victoria usage mode noted. Tks.
5) Considering the use of a professional data recovery is out of question. I can't afford paying one.
6) I myself have given up on Seagate HDD for a long time. This drive is a friedn's drive that I was using to do some backups and now I have to give it back to him.
Well, I am not an expert on HDD engineering, but I think it could be fixed. What I can figure out is that it maybe has lost its MBR/GPT table/Vol and probably its SMART table. flashing its firmware could solve this problem but I would lose data, is that possible?
Tks.
PostPosted: February 20th, 2018, 7:49
need the data is 1 thing but fixing it for reuse its another
forget about it
whats the capacity you get ?
judging by the make and model I doubt that
most likely not
So since you say PRO DR is out of the question
you need to know first, that this drive has most likely heads problem and or media damage
but if you insist, upload the terminal log here
PostPosted: February 20th, 2018, 10:13
I think it will be close to impossible for you to get any data out of that drive as let's take in consideration that it's not even YOUR drive ....
Ask permition to the owner of the drive to continue on and if you insist you will need at least a TTL adaptor and plug it to the drive like this :
http://www.hddoracle.com/viewtopic.php?f=46&t=192
http://www.hddoracle.com/viewtopic.php?f=6&t=193
At this point DO NOT ISSUE any commands to the drive and DO NOT USE ANY 7200.11 commands posted on the net as they will kill your drive for good.
Just power on the drive and check what log the drive sends at power up to the terminal software.
Also on your model of drive if you don't have a way to properly backup the sysfiles, modules and ROM is very risky to continue with firmware manipulation.
If you could somehow backup all the SA you could then start by disabling some flags on sysfile 93 and attempt to disable media cache, etc ... But if your BIOS is picking up the drive as 801.6 GB then either the drive have some firmware issue related to translator or bad heads/surface not initializing the firmware as it should at boot up or your BIOS have some limitations.
Test with Victoria in PIO mode.
Remember the more you power on the drive the less the chances are for someone to recover the data. If you mess things up badly not even the best pro in the world will be able to recover the data later.
PostPosted: February 21st, 2018, 1:45
The bios is too old for this hdd....That's why is seen as 800gb capacity.
You need a better/newer motherboard to support it.
www.datasave.ro
PostPosted: February 21st, 2018, 11:46
I know it doesn't help you, but I'm really curious why you tried to write zeros to the hard drive?
Blizzard Data Recovery
PostPosted: February 21st, 2018, 17:37
I suppose the data is not that important to him
PostPosted: February 23rd, 2018, 16:56
@igirao :
Did you try to connect it on a Linux system, and clone it or image it with ddrescue or HDDSuperClone ? You'll need another drive with at least a 3TB capacity. But it should be recognized first, it should appear with the correct capacity when you type "lsblk" in the terminal (be sure to note which is which, or you'll end up screaming like a witch !). If you can manage to copy everything, or almost everything to a healthy drive (it could be very slow but if you're lucky and the issue is only surface damage / bad sectors and you did not stress it too much by doing all that stuff you should manage to get a good portion), then you can analyze the output with reputed recovery softwares and less stress.
Some Seagate enclosures (I've got one like that) have a special kind of formatting at the controler level which translates regular 512 bytes sectors into 4KB sectors, providing compatibility for drives of higher than 2TB capacity with older systems, but making the content inaccessible without the native enclosure ; if the interface somehow got corrupted it may explain the situation (not sure at all, but that's something to consider). If you do manage to make a clone / image, and still can't access the content, maybe someone could help you fix this by analyzing the first few MB, containing the partition table and whatnot.
But if you can neither read nor write anything all that is probably moot...
PostPosted: February 24th, 2018, 14:13
The motherboard is too old. I suppose if the drive is connected to a SATA port of a reasonably current motherboard, it would be readily readable; unless there is a 4K/512 sector issue, and/or part of the data is overwritten already.
PostPosted: February 24th, 2018, 14:24
Also I understand the drive came from an enclosure?
So before you do anything drastic check the drive was not encrypted.
PostPosted: February 24th, 2018, 17:06
I did not try to write zeros to the hard drive. I just run diskpart to see if it could be of any help. That's what it shows.
PostPosted: February 24th, 2018, 17:10
It surely is.
PostPosted: February 24th, 2018, 17:18
then why did you use the clean command in diskpart ? If it had worked then all the data would have been destroyed
PostPosted: February 24th, 2018, 18:21
By the way, is it all the data or just the partition tables (or boot sectors if there are no partition tables)?
PostPosted: February 24th, 2018, 18:33
Just to be clear, Diskpart Clean removes partition or volume formatting. For MBR drives it also removes hidden sector info and for GPT it overwrites the protective MBR. The device would then be ready to initialize. The parameter ALL writes zeros to the entire device.
PostPosted: February 24th, 2018, 18:35
Clean would probably delete boot sector and partition table. That would already be a bad move for him.
Clean all, from the help of diskpart, should write zeros to all of the drive. Absolutely bad move for him. :shock:
PostPosted: February 24th, 2018, 18:37
Yes, very bad! I am hoping he can clarify why that was attempted. Maybe some bad info on a forum needs to be corrected. But I guess we can't really fix the Internet :)
PostPosted: February 24th, 2018, 18:42
abolibibelot wrote:
@igirao :
Yes, I did it. I used Kali linux and disk utility but it did not see the drive. Then I shutdown Kali and got this: pls see the picture.
