 Post subject: Recover corrupted excel file.
PostPosted: July 14th, 2014, 5:06
Hi all,
I have a case that the client work on an exists excel file, he try to save the file on a different name,
sines than the file was corrupted an could not be open at all.
I try the auto save of excel, but nothing there..
I try several fix software but the most of them get me a blink results.
some of the software get me corrupted result with windows symbols font, and the text box say "File not loaded completely".
I have an older version of the file from few mounts ago, that can assist me?
can anyone have an recommended fix software, or a way to get fix that excel file?
Thanks.
 Post subject: Re: Recover corrupted excel file.
PostPosted: July 14th, 2014, 8:26
What version of Excel were they using?
Have you tried opening it up in the latest version on Excel?
I had it in the past where say a 2003 file wouldn't open but opening it in 2010 it would repair it & open it ok.
Then I just saved the file to a new location.
Have you tried Open Office? might be worth a try just in case?
Microsoft have this link http://office.microsoft.com/en-us/excel ... 34656.aspx
Also http://www.stellarinfo.com/excel-recovery.htm $49 for Excel Soho license $79 for Word, Excel & Powerpoint Soho
Loki
PostPosted: July 14th, 2014, 8:46
Thanks for your replay,they using office 2007.
Yes, i try to open and repair it using office 2003,2007,2010 and its all the same.
and i try open office as wall, i get windows symbols.
about the excel repair by stellar, i try i too. i run it about 12 hours (Demo version) on this file and still waiting..
if i try with good file it open it for repair in 2 sec..so should i'll wait as long as it take?
Thanks again.
PostPosted: July 14th, 2014, 10:18
Its possible it didn't save properly & the corruption is too bad.
Using google search comes up with various softwares you could try? ie http://www.excelfilerepair.org & others.
Most likely you will have to try various until you find one that either works or you decide it's unrecoverable.
Loki
PostPosted: July 14th, 2014, 14:38
Did you try to open in HEX and see is any data in that corrupt excel file.
Try to compare with good excel file.
Sistrum Data Recovery
http://www.sistrum.mk/en
PostPosted: July 16th, 2014, 12:34
You may also try this one: R-Excel.
Data recovery, backup, protection.
R-Tools Technology, Inc
PostPosted: July 16th, 2014, 14:03
Didn't think it supported 2007?
Standard Windows Explorer - style interface.
Host OS: Windows 98, ME, NT, 2000, XP, 2003, Vista.
Supported *.xls file formats: Microsoft Excel 97/2000/XP/2003.
Automatic or manual search for Excel sheets. R-Excel searches for Excel sheets on all (including network) disks visible by the host operating system.
I suppose the excel file could be either .xls or xlsx depending how it was saved
Loki
PostPosted: July 16th, 2014, 15:26
agreed, you should compare the header of valid file with corrupt file, if the header is ok, there are chance to repair the files, else it will be difficult.
you can get header information here...
http://www.filesignatures.net/index.php?search=xls&mode=EXT
Data Recovery Pakistan
PostPosted: July 17th, 2014, 12:39
I think it supports, at least worth trying.
PostPosted: June 2nd, 2015, 13:43
Banned User
Hi, I have the same problem but the solutions do not work for me. So, I would like to know more recovery tools. I'm a novice in this, but we need recover an Excel file quickly, so we need a solution. The version of Excel is 2010.
Thanks!
PostPosted: June 2nd, 2015, 14:08
Thanks!
Can you post the exel file or is it confidential ?
If the data is not confidential you can try to post the damaged file so we could check it.
PostPosted: June 2nd, 2015, 18:47
If it is a .xlsx and not a .xls, you might also try .zip file repair tools. .xlsx are just a zipfile of around 8 folders and 15 files IIRC. You may be able to unzip damaged file with a util, and repair it manually. I *think* I saw a talk at a InfoSec conference about this, or an online blog or something, but cant remember where. search.
for example, I right-click on excel spreadsheet and from 7-zip context-menu choose extract here..
PostPosted: June 3rd, 2015, 12:36
Banned User
The file is of my job, I can not share it. We tried with the .zip file repair tools, but we had not results. What excel recovery tool can you recommend to me?, please I need your opinion, it doesn't matter if is shareware or freeware.
PostPosted: June 3rd, 2015, 13:00
How did it get to be "corrupted" ?
Did the drive fail? Or did you delete it and use software to recover it?
PostPosted: June 3rd, 2015, 14:25
Try to start by opening the file with Hex Editor to see if the content of the file is still valid and if you can carve data out of it at all.
PostPosted: June 3rd, 2015, 22:18
I thought Didier Stevens had some Office stuff, but I think now it is the .pdf analysis I was looking at. his stuff is great, so that should be checked out by anyone that does any sort of file carving/forensics. But I doubt any serious forensic guy hasn't already seen Didiers work.
http://blog.didierstevens.com/
this may be of use, Lenny Zeltser is also brilliant.. those 2 guys alone make me feel like a dumbass!
https://zeltser.com/analyzing-malicious-documents/
be warned, there is quite a bit of work involved. Sometimes these files are simply too far gone, and you spend way more resources than what you will ever get rewarded for.
PostPosted: August 22nd, 2017, 7:48
Banned User
Well, to recover your Excel file try to make the Excel file read only and then recover it.
Here follow the steps to do it:
 Click on the ‘Office button’ and then select ‘save’ for a new document or ‘save as’ for the previously saved document.
 Next, you have to click on the ‘Tools’ and then select ‘General Option’.
 Click on the ‘read-only’ checkbox to make document read-only.
 Now you have to open a new and blank .xlsx’ file and then copy the whole data from the corrupted Excel file to this new one. Now simply save this file and try to open it again.
Hope in this way you can recover Excel file.
PostPosted: May 17th, 2018, 4:08
Banned User
hello whats going on here
