 Post subject: pcr extension
PostPosted: November 1st, 2018, 4:17
please help any one!!! pls help!!! i am tried to find pcr extension opener. none of the links are working. even i dont found any application to open that
 Post subject: Re: pcr extension
PostPosted: November 1st, 2018, 5:33
Why so scream? Here is:
https://disk-on.ru/pcr
PostPosted: November 1st, 2018, 8:29
You could ask member @migann, per this post: https://forum.hddguru.com/viewtopic.php ... 97#p192997. He has written such a tool and sometimes agrees to convert PCR files as a kindness, I believe.
Here is the link to which you can submit files for conversion: https://disk-on.ru/pcr
PostPosted: November 1st, 2018, 10:17
PC-3000 should open that ! And if you don't know about pcr extension most likely you don't know how firmware resources are used as well.
HDDs are not like cell phones. You can't just "flash" a firmware from a database/resource and expect for it to work.
What tools do you have to work with HDD firmware ? MRT ? SeDiv ? etc ... ?
PostPosted: November 1st, 2018, 10:43
sir i am not a professional data recovery agent. i was just trying to repair my bricked hard drive. i found my hard drive only firmware but the extension is pcr.and i waste my whole day researching how to open pcr file and none of then worked
PostPosted: November 6th, 2018, 10:38
Guys this service is now switched off
please use new type of converter - attach and send file to e-mail pcr@disk-on.ru now in testing mode
PCR extracting. Remote data recovery from DVR. Skype: yustik74
PostPosted: November 6th, 2018, 14:53
Please do open a new thread on the Conventional hard drives section of the forum with your specific problem. Don't forget to mention the full model of your drive, etc ...
HDDs are not like cell phones. You can't just flash entire firmware on them to fix them ! Also if you don't have firmware tools like PC-3000 (costs at least $6000) you will not be able to use those posted firmware resources anyway ...
http://www.hddoracle.com/viewtopic.php?f=56&t=176
Why not publish an off-line extractor ? :?
PostPosted: November 7th, 2018, 0:40
because online service simple to fix and update :-)
