 Post subject: New version of UFS Explorer
PostPosted: February 19th, 2019, 3:16
New version 7.5 of UFS Explorer Professional Recovery include a several updates, including support of SCSI drives with non-standard sector size (like 520 bytes etc.) and support of R-Studio image file format (RDR-files).
 Post subject: Re: New version of UFS Explorer
PostPosted: March 11th, 2019, 14:07
What's new in UFS Explorer Professional Recovery version 7.6:
* Support of BitLocker encryption (with user password and recovery key);
* Support of ReFS 3.4 format (Windows Server 2019);
* Support of Microsoft data deduplication on ReFS volumes;
* Fixed bug reading Core Storage metadata in "pending state";
* Support of ZFS-on-Linux custom ZFS metadata;
* Support of "bogous" FreeNAS RAID10 (mix of simple disks and mirrors);
* Fixed bug with multiple detections of NT LDM volumes.
PostPosted: March 29th, 2019, 14:11
What you need to know about UFS Explorer products - Video Presentation https://youtu.be/m0nEz9-oBPA
What's new in version 7.7:
* Added masking of bad blocks (replacing bad blocks with custom pattern);
* Added AES XTS support for BitLocker;
* Updated RAID configurations save/restore procedure:
- Added support of EWF-files in saved RAID configuration;
- Added support of virtual (VFS) files in RAID configuration;
- Custom RAID names are now preserved.
* Reworked LVM module for latest LVM2 (with added DM RAID function);
* Assignment of LVM names to LVM partitions and logical volumes;
* Option of automatic saving of scan state immediately after full scan;
* Simplified process of removal of opened storage components;
* Regular update to embedded pictures viewer.
PostPosted: March 29th, 2019, 14:23
Nice Iurii
With all these fast updates, you may need an extra digit to the version number :-D
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: March 30th, 2019, 1:24
Do not worry: latest for version 5 was 5.25.1 ;) so we have a lot of numbers !
PostPosted: April 22nd, 2019, 5:07
What's new in version 7.8:
* Added virtual sector size transform function (for SATA drives and disk image files);
* Added LVM logical volume recovery manager UI:
- Search for older versions of LVM configurations;
- Open logical volume from found configurations;
- Search for missing physical volumes;
- Manual definition and assignment of missing physical volumes;
* Extended context menu functions in partition manager;
* Drobo support: using of alternative drive IDs, big volume sizes;
* Fixed bug with scanned Btrfs file system filtering.
More details: https://www.sysdevlabs.com/product.php? ... r_cat=tech
PostPosted: May 22nd, 2019, 12:37
What's new in version 7.8.1:
* Saving virtual file system structure for off-site revision;
* Added function to save/restore files/folders selection state;
* Loading of virtual FS structure for review and files selection;
* Added possibility to rename temporary disk in user interface;
* Fixed problem with ExFAT root folder validation during full-disk scan;
* Fixed issue with recognition of SCSI transport for fiber-channel connected storages;
* Support of switching to SCSI transport even when SCSI INQUIRY command fails.
What's new in version 7.8.2:
* Fixed bug with reading big files on VMFS6;
* Added support of "CLOUD" reparse points on NTFS (files from OneDrive etc.);
* Read-only support of "streamOptimized" (compressed) format of VMware VMDK files.
PostPosted: July 3rd, 2019, 13:36
What's new in UFS Explorer Professional Recovery version 7.9:
* Added support of DeepSpar image file format (DDI, including defect block maps);
* Added Virtual Pattern storage for construction of over-degraded RAID;
* Added function of converting span of sparse components to sparse virtual disk;
* Added function to open base files of sparse virtual disks for fine-tuning of VD container;
* Added function to open disk as virtual disk for full-disk clones of virtual disks;
* Fixed problem with recognition of BitLocker when recovery key comes with version not equal to 1;
* Fixed bug with BitLocker "plain key" format;
* Fixed bug applying delta files in format of Split-VMDK;
* Added option to apply masks to folders for copying with filter;
* NTFS tail processing is now included into quick scan (to file system indexing).
PostPosted: July 23rd, 2019, 6:46
What's new in version 7.10:
* Support of 'long' deduplication reparse points on NTFS (Windows Server 2019);
* Fixed bug reading files from Microsoft Deduplication Database in some scenarios;
* Fixed bug reading directory structure of latest ReFS3 file system;
* Apple Core Storage: fixed crash bug, added block reference type "16";
* Added search for BitLocker partitions to Partitions Manager;
* Added BitLocker indication to Partitions Manager;
* Major rework of NTFS scan procedure:
- Added old/duplicated objects removal from scan result;
- Better processing of lost files (with descriptors out of MFT);
- Changed priorities of file names processing;
- Fixed bug in folder structure recovery by INDX entries;
- Fixed bug with scan resumption and calling Recycle Bin processing;
- Added support of Recycle Bin indexes with version 2.
* Added Portuguese software interface language.
PostPosted: August 19th, 2019, 12:12
What's new in version 7.11:
* Added support of DeepSpar DDI over network;
* Added to Apple Core Storage:
- Plain blocks, reference type 11;
- Support of compressed multi-block XML metadata.
* Added 'Pause' function to file copying procedure:
- Quick pause/resume for temporary 'releasing' disk;
- Option of finishing current file and with ability to change destination path.
* Support of NTFS with cluster size over 64KB;
* Support of Windows Server 2019 Storage Spaces metadata;
* Added cluster size indication to file system properties;
* Fixed bug using 'Open' dialog with scan results of virtual disks.
