Post new topic Reply to topic  [ 86 posts ]  Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: New version of UFS Explorer
PostPosted: August 11th, 2020, 8:40
What's new in version 8.4:
* Added DeepSpar Disk Imager network terminal to 'Tools' menu;
* RAID builder dialog:
- Added virtual sector size transform to disk menu;
- Changed icons to indicate component type and read method (System/ATA/SCSI);
- Ability to load partial RAID config via this UI (when components are missing);
- Displaying drive serial number or image file path as ID for missing components;
* RAID configuration files:
- Save/restore drive read method (System/ATA/SCSI);
- Drive Serial Number is now saved to config file;
- Restore RAID config with verification and priority of drive Serial Number;
- When disk image is not found, searching it at the same location on other drives;
- URCF extension is now mandatory for RAID configuration files;
* Added error reporting for bad RAID configs when opened via general 'Open' dialog;
* Added 'Skip file' button to copying dialog (to skip individual files);
* Raw recovery:
- Added file name generation for .contact, .vcf, .fb2 files;
- Recovery of name (Original/Internal) and build date from Windows executables;
- Adjustment of file size for EXE/DLL/SYS files to match size of sections and signature;
* Speed-up of properties (preview) extraction for Windows executable files;
* In disk list: change drive icon to ATA/SCSI when drive works with custom method;
* Added ability to change read method via storage properties;
* In 'Open device': devices are re-sorted by drive number.
PostPosted: August 11th, 2020, 14:28
Impressive list Iurii, thunbs up 8)
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: September 3rd, 2020, 5:08
What's new in version 8.5:
* Added Adaptec RAID6 to 'Visual mode' of RAID Builder;
* Added 'Grid pattern' view mode to RAID Builder:
- Conversion of standard patterns to grid (including delay, shift etc.);
- Visualization of custom patterns created with RDL;
- Active pattern cell corresponds to hexadecima viewer position;
- Stripes naviagtion using pattern grid;
- Support of both vertical and horizontal pattern view modes;
* Added 'Entropy report' (histogram) to 'Reports view' of RAID Builder:
- Shows entropy histogram of all readable storage components;
- Configurable x-scale, y-scale and y-adjustment of the histogram;
- Supports sigma-smothing of histogram values;
- Custom histogram colors;
- Support of dynamic report reconfiguration when drives order is changed;
- Pick address location from report picture to navigation in hexadecimal viewer;
* In disk imager: handle BSY/DRQ status as a reason for retries and pausing imaging;
* Reworked procedure of deleted files recovery from EXT3/EXT4 file systems;
* Updated format of 'scan status database' and 'virtual file system' files;
* Photo viewer adopted for new digital camera raw formats of:
- CANON EOS-1D X Mark III, EOS 250D; Fuji GFX 100, X-Pro3, X100V, X-T4;
- Nikon D780, Z5; Pnanasonic DC-G100, DC-TZ95, DC-G90, DC-G95, DC-GX880;
- Sony DSC-RX100 VII, a7R IV, a6100, a9 II; Olympus TG-6 etc.
PostPosted: September 25th, 2020, 19:34
What's new in version 8.6:
* Added tool for finding RAID6 Reed-Solomon code multiplicator coefficients;
* Added tool for unwrapping eCryptFS passwords from wrapped password files;
* Support of password unwrapping from Synology 'key file' backup and legacy keystore;
* Added address translation from component to RAID location for RAID0/1/1E/3/5/6/Span;
* Enabled support of address translation from disk-on-disk storage to parent;
* Raw data comparison tool:
- Added ability to change components order;
- Added tool for address translation to component;
* Indication of file chunk addresses on Btrfs file system and its scan result;
* Indication of inode offsets on Btrfs file system;
* Fixed rare crash bug that was happening at the end of storage scan;
* Fixed bug of failure of writing data to disk (modifying content) in SCSI mode;
* Modified handling of APFS metadata damage to show more structure when tree is damaged;
* Fixed several bugs with Btrfs file system scan;
* Raw recovery:
- 'Title' is now recovering as file name for .html and .wpl formats;
- Added title and date extracton from ODT/ODS/ODP document files;
- Fixed crash bug on invalid exe-file data.
PostPosted: September 25th, 2020, 19:39
Nice job Iurii :good:
PostPosted: October 19th, 2020, 15:18
What's new in version 8.7:
* Drobo BeyondRAID:
- Reworked BeyondRAID internal reading procedure;
- Fixed bugs that caused errors in degraded RAID virtual reconstruction;
- Added recovery with two missing drives of dual redundacy configurations for 4-8 drives;
- Simplified RAID builder dialog for BeyondRAID configuration;
* ExFAT scan procedure:
- Additional procedure for finding previous file system align after storage re-partitioning;
- Reduced number of 'found file systems' with wrong align;
* NTFS: enabled direct file system access when DATA attribute is damaged;
* HFS+ file system:
- Fixed few bugs preventing detection of several partitions during single scan;
- Reduced memory use by better isolation of files between found file systems instances;
* Fixed several problems in software versions for macOS:
- Fixed crash bug in copying procedure when popup dialog window have to appear;
- Fixed rare bug causing dialog sheet to 'stuck';
- Fixed problem of displaying some auxilitary UI captions;
- Added software notarization for macOS version 10.14 and later;
* Added S.M.A.R.T. monitor window:
- Support of most important S.M.A.R.T. attributes for ATA drives (under all OS);
- Disk temperature and percent of spare space usage for NVMe drives (Windows);
- Disk temperature and growing list (G-List) size for SCSI drives (Windows, Linux);
- Manual or automatic data refresh;
- Function to enable/disable S.M.A.R.T. monitoring on ATA/SATA drives.
Users browsing this forum: maddin and 6 guests
cron
