 Post subject: how to use sediv to just clear SMART
PostPosted: February 21st, 2019, 16:00
HI
i downloaded sediv from officail site and want the steps to clear smart for hard disk toshiba 80 gb
thanks
 Post subject: Re: how to use sediv to just clear SMART
PostPosted: February 22nd, 2019, 6:02
you need to purchase it only than you will be able to do something.
Data Recovery Pakistan
PostPosted: February 22nd, 2019, 14:39
Demo sediv can clear smart.
PostPosted: February 22nd, 2019, 15:47
thanks Sir.
PostPosted: February 22nd, 2019, 15:50
that sounds good to me :D i Hope you till me the steps for that Sir, thanks anyway.
PostPosted: February 25th, 2019, 4:40
i hope any help from the experts here, just simple steps to clear SMART for old hard disk Toshiba 80 GB Sata using Sediv or any DEMO tool
PostPosted: March 9th, 2019, 20:11
If you have a FULL paid version of SeDiv use the option to clear SMART on the software, i don't think this will work on the DEMO. Even if it does work there is no reason for you to clear S.M.A.R.T. at all. Bad sectors will not go away and entries on G-List will still display on S.M.A.R.T. so you can still have the drive report S.M.A.R.T. as "bad" even if you regen the smart sector using any firmware tool or even direct ATA VSC ...
Why do you need to clear S.M.A.R.T. on your drive ?
Also there are some possibilities that SeDiv will not work with older Toshiba drives. At least with 80 GB IDE Toshiba i'm positive it will not work and the VSC to clear S.M.A.R.T. on those is not the same as the one to clear S.M.A.R.T. on SATA so if you have SATA Toshiba you should be OK with a full version of SeDiv because even if it can't properly read CPs of your model it can issue the VSC to clar S.M.A.R.T. .... Assuming that that is all that you need ...
Users browsing this forum: girishp and 12 guests
