 Post subject: Sata WD HDD changing model number and serial number
PostPosted: February 24th, 2019, 12:40
I need restore my old hdd on new one, cloning is sucesfull, but one app dont work, because license depend on hdd serial and modelu number. Both HDD are the same from WD. Is some solution how can I change these numbers? I am ready to pay.
 Post subject: Re: Sata WD HDD changing model number and serial number
PostPosted: March 5th, 2019, 0:51
Which program is that ? If your computer runs on Windows, perhaps the HDD model is stored in a registry key, which you could simply edit to replace it with the current model... Open regedit and do a search with the serial number from the former drive.
Or perhaps you could explain the issue to the developper and get a new license for the new drive...
PostPosted: March 9th, 2019, 20:02
If you do want to pay ...
https://www.ebay.com/itm/Drive-ID-Passp ... 2674160463
Also there is a do-it-yourself way ... But WDMarvel and it will change the serial and model of your drive ....
But it will be way more expensive than using that eBay service...
Regards.
