This is a bit the follow of the forum of hack3rcon , concerningt the BEST SOFTWARES FOR HDD RECOVERY
I have an 3TO(TB) HDD problem with GPT partition (some tool still recover only fat32 and NTFS), it is asking to reformat the drive, there is mainly series/ movies on it and I know the data is till there. How do I Know?? Simple, I've tested already around 52 Recovery programs and some of them where able to retrieve the data. Some were JUNK, for partition pb (not working at all) I GRADE THEM "E" Some were BAD (recovering only PART of the data with wrong name of the files) GRADE THEM "D" Some were incomplete (recovery only PART of the data with partially good name files) GRADE THEM "C" Some were fine but incomplete (recovering ALL the data but with wrong Name of the files)...Not bad but ;-(....Grade them "B"
Well....NONE of the tool for the moment recovered ALL THE DATA with good name of the files, i'm searching for the "A" GRADE
On each case you need to chose software that better fits your needs, but in my forum, I Speak of the worst case, partition problem with clusters problems.
When I Recover a serie (like game of throne) I cannot use it because even if I have recovered all the episodes, I don't know in which order to read them, It would take 10 years to look all files and renames them good, so it 's not an option for a good recovery when you recover 10000 series and episodes.
It takes around 2 DAYS to recover a 3TO drive full of data like series, so testing a software is very long.
I'm not on my main desktop computer, but here are some of the tools I have tested: Concerning partition pb.... Here are D (they usually recovers file from non partition pb drive) Recuva, ,Testdisk,Recover My Files, PhotoRec, Doyourdatarecovery, amazing data recovery, 7thsharedatarecovery, Boysoft Data Recovery, Idatarecovery bitwar data recovery, allstardatarecovery, recovermyfiles, mrtdatarecovery, Wondershare Data Recovery , remo recover, Ontrack EasyRecovery
Here are C: Disk Drill, R-Studio, R-Undelete, Raise Data Recovery, EaseUS Data Recovery, Minitool recovery, Phoenix recovery, Boysoft Data Recovery, getdataback
Here are the B's: Data Rescue
Of course, there is much more shitty programs than good one as you can see but these results with my 3TO HDD don't lie, I don't think anyone as spend hours like me, and also, I tend to try again the program when version has improved after around 1 year.
I will list soon list all (many more D,C and the other B's) , but I am still searching for the Best program recovery, THE A GRADE hasn't shown up.
