 Post subject: recomandation for USB to SATA adapter.
PostPosted: February 13th, 2020, 13:24
What USB3.0 to SATA would you recommend? Or what would you not :)
I plan to buy one from ANKER: https://www.anker.com/uk/products/varia ... TAA-02BUKU
It has USB 3.0, external supply and it works with 2.5" and 3.5". Thanks
 Post subject: Re: recomandation for USB to SATA adapter.
PostPosted: February 13th, 2020, 16:56
Try to find one that supports interface voltages of 1.8V, 2.5V and 3.3V.
CP2104 and PL2303HX rev D are two bridges that can support these lower voltages, but you will probably need to modify them by adding your own 1.8V or 2.5V LDO regulator. Note that the PL2302HX has many clones (fakes) which do not work with Prolific's drivers.
PostPosted: February 13th, 2020, 22:19
He is talking SATA conversion but you are talking UART ;-)
the Anker one should be fine.
PostPosted: February 14th, 2020, 2:11
Frank ,
Come To India For a Vacation ,Be My Guest This is not what he is asking my friend .As fas as the question goes i would say invest in a dock from startech ,anker,orico etc ,I like orico quite a lot
PostPosted: February 14th, 2020, 4:02
Based on the reviews Orico seems to be a good choice. And they are available in my country also. Thanks
Users browsing this forum: Google Adsense [Bot] and 3 guests
