Hello
I have external HDD Samsung (inside it is Seagate Baracuda) D3 Station 2TB contaning one NTFS patition. I've successfully cloned whole disk using ddrescue with no errors. From cloned image I can mount NTFS partition and seems that everything is fine except one file:
root@ryzen:/mnt/SAMSUNG_2TB# du -sh * | sort -h
du: cannot access 'EDU_VIDEOS/coursera/Coursera - Stanford University - Jeff Ulman - Automata/02 - Week 2 Regular Expression and Properties of Regular Languages/03 - 7. Decision algorithms for regular languages (41 min.)/7_rs1.pdf': Input/output error
`dmesg` shows nothing suspicious, except:
[ 1041.102751] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[ 1041.105653] ntfs: volume version 3.1.
[ 1268.754273] __ntfs_error: 6 callbacks suppressed
[ 1268.754274] ntfs: (device loop0): map_mft_record_page(): Mft record 0x1c52 is corrupt. Run chkdsk.
[ 1268.754287] ntfs: (device loop0): map_mft_record(): Failed with error code 5.
[ 1268.754292] ntfs: (device loop0): ntfs_read_locked_inode(): Failed with error code -5. Marking corrupt inode 0x1c52 as bad. Run chkdsk.
Then I've done smartctl long test with following results:
root@ryzen:~# smartctl -a -d sat /dev/sdd
smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.4.34-1-pve] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Seagate Barracuda 7200.14 (AF)
Device Model: ST2000DM001-1E6164
Serial Number: W1E903F0
LU WWN Device Id: 5 000c50 07d3083c7
Firmware Version: SC48
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Mon Jan 25 08:53:36 2021 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 584) seconds.
capabilities: (0x73) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 232) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x3081) SCT Status supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 113 100 006 Pre-fail Always - 54720264
3 Spin_Up_Time 0x0003 095 095 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 67
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 100 253 030 Pre-fail Always - 30065584744
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 136
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 53
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 001 000 Old_age Always - 7 7 65535
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 054 045 045 Old_age Always In_the_past 46 (Min/Max 21/53)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 6
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 765
194 Temperature_Celsius 0x0022 046 055 000 Old_age Always - 46 (0 20 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 56h+06m+40.808s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 846975072
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 4758693957
SMART Error Log Version: 1
ATA Error Count: 2
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 2 occurred at disk power-on lifetime: 63 hours (2 days + 15 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
25 00 00 ff ff ff 4f 00 00:00:12.218 READ DMA EXT
25 00 08 c0 05 60 40 00 00:00:12.217 READ DMA EXT
25 00 20 ff ff ff 4f 00 00:00:12.210 READ DMA EXT
25 00 28 ff ff ff 4f 00 00:00:12.149 READ DMA EXT
25 00 20 ff ff ff 4f 00 00:00:11.675 READ DMA EXT
Error 1 occurred at disk power-on lifetime: 63 hours (2 days + 15 hours)
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed without error 00% 132 -
# 2 Short offline Completed without error 00% 126 -
# 3 Extended offline Aborted by host 90% 126 -
# 4 Short offline Completed without error 00% 126 -
# 5 Short offline Aborted by host 70% 126 -
# 6 Short offline Completed without error 00% 126 -
# 7 Short offline Completed without error 00% 126 -
# 8 Short offline Completed without error 00% 106 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
As far as I understand above output it all seems fine maybe except this line:
which is bug in old 2.6 kernel!
http://patchwork.ozlabs.org/project/lin ... savvy.com/ and I have no idea how this could happend because I'm using latest kernel.
So after this I've issued badblocks -nsv /dev/sdX -o badblocks.log
After this I got 11GB! log file full of bad blocks and no commands (fdisk, lsblk) was able to access hdd anymore. Oh, and dmesg was full of messages like those:
[153480.139575] Buffer I/O error on dev sde, logical block 3206647748, async page read
[153480.139684] Buffer I/O error on dev sde, logical block 3206647749, async page read
[153480.139790] Buffer I/O error on dev sde, logical block 3206647750, async page read
[153480.139895] Buffer I/O error on dev sde, logical block 3206647751, async page read
[153480.140004] Buffer I/O error on dev sde, logical block 3206647744, async page read
[153480.140117] Buffer I/O error on dev sde, logical block 3206647745, async page read
[153485.143004] buffer_io_error: 9681598 callbacks suppressed
So after this I've removed disk from case and connected it directly to mainboard via SATA and run again badblocks and smartctl long. The results for badblobcks are narly same as previous: badblocks reports errors bud smartctl does not. Here is output after long test:
root@ryzen:~# smartctl -a /dev/sda
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Fri Jan 29 17:38:54 2021 CET
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
been run.
capabilities: (0x7b) SMART execute Offline immediate.
command.
power-saving mode.
1 Raw_Read_Error_Rate 0x000f 116 100 006 Pre-fail Always - 106098520
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 69
7 Seek_Error_Rate 0x000f 100 253 030 Pre-fail Always - 42950569832
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 189
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 55
189 High_Fly_Writes 0x003a 099 099 000 Old_age Always - 1
190 Airflow_Temperature_Cel 0x0022 066 045 045 Old_age Always In_the_past 34 (Min/Max 34/36)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 8
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 767
194 Temperature_Celsius 0x0022 034 055 000 Old_age Always - 34 (0 20 0 0 0)
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 67h+06m+11.667s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 1100316256
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 5016214998
ATA Error Count: 2
# 1 Extended offline Completed without error 00% 187 -
# 2 Extended offline Completed without error 00% 132 -
# 3 Short offline Completed without error 00% 126 -
# 4 Extended offline Aborted by host 90% 126 -
# 5 Short offline Completed without error 00% 126 -
# 6 Short offline Aborted by host 70% 126 -
# 8 Short offline Completed without error 00% 126 -
# 9 Short offline Completed without error 00% 106 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
I've tried Long Generic Test under SeaTools Bootable directly from Seagate. This shows no errors.
1. why does badblocks show erros when smartctl and SeaTools Bootable does not?
2. Is my drive dying (it has just few hours powered up as shown in smartctl) or do I have just corrupted FS?
3. is badblocks still relevant on new drives?
Thank you very much
